Can't hear playback through Headphone socket, only through speaker monitors!
Using Behringer 1622x USB Mixer with M-Audio M8 USB Interface which both feed into computer running Win.10 with Cakewalk 7.
Have Power Amp.plus speakers. With Mic. into channel on mixer and set to record I can hear signal using Headphones to get balance etc. but I can't playback through headphones, only through speakers, so can't record next track! Seems as if Mixer is being bypassed and going straight into Amp/Speakers. Any ideas please, greatly appreciated. Thanks. Mike Chilvers
Re: Can't hear playback through Headphone socket, only...
I suggest you contact Behringer Customer Service for advixce. Without the setup in front of me, it's hard to figure out the wire routeing, switch positions, ect. that may be leading to this problem. As they would be the people most familiar with the gear, they'sd be the people to ask. http://www.music-group.com/support/behringer/askquestion
See if another audio source connected to the mixer produces the same results. Try with the same cable and then with another cable. The purpose of this procedure is to determine if it is the cable and/or the laptop. (Sound card problem???) or mixer.
Is it ALL audio or just specific audio from for instance, a music application? Does it cut out using iTunes?
The mixer may have a bad or oxidized input. Try a different input channel? Are you using headphones to listen? It may be the headphone amp? OR, if audio is produced via amped speakers, it may be the mixer output. Does the mixer have metering? Do the meters also cut out? Does the laptop do the same thing if plugging in headphones to the laptop directly (no mixer)?
hello. Im not too familiar with Protools (mainly because its a headache right out of the box), but MY understanding is that Protools won't recognize a lot of external audio devices. (such as behringer)
however..if you are able to record and 'see' the audio there, just not hear it, there might still be a solution, & seeing as how i never used protools, it still might just work.
First of all:
if you're using the UCA-200 external usb box connected with rca cables, then my solution SHOULD work, as it is what i did to get mine to finally do the same thing.
#1) you will need to pick up (x2) RCA-1/4 jack adapters . (radioshack, about $2 each)
#2) insert a red and white rca cable in the RIGHT side of the Mixer's CD/Tape out .....the other end of the rca cables will go into the UCA-200 INPUT.
#3) with 2 more cables in the OUTPUTs of the UCA-200, put the rca-1/4 jack adapters on both cables, insert them back into the Mixer inputs 9/10 (in the analog 1/4 instrument inputs)
#4) adjust volumes accordingly, make sure channel 9/10 isn't muted, headphone volume is up, etc..
.......if that didn't do the trick, then you will need to go into the Audio Settings menu on your computer..(or protools) and change the default playback device to your mixer (probably named Generic USB or something similar)
I really hope this helps somewhat, because i remember going through the same thing & it took a looong time to find the correct awnser.
best of luck!
*also*
check for any updated drivers for your mixer! (I personally recommend you do a Google search for Asio4all drivers, they're pretty good)
if your awnser is A), i would suggest going into your computer's Audio Settings menu, and select the mixer as your default playback device.
Sounds like the output cable from the 802 is not correctly pinned to your input on the computer. Fred is on the right track but you may need to take it a bit further.
It may also be helpful to use a Pro USB audio interface such as the Digigram UAX220v2 (line level version).
If you wish to use the computer's on board sound card consider an IHF/Pro interface that converts balanced audio to unbalanced , and the proper cables. Two 3-wire balanced 1/4-inch from the 802 to the left and right inputs of the interface (XLR Male), then RCA (Red and White) to a 1/8-inch TRS Plug cable onto the the computers audio input.
Henry Engineering's Matchbox HD comes to mind.
Good Luck.
WIthout a quality audio interface the answer is you don't... You need to procure an audio interface for the computer. The internal audio systems of computers are too noisy to get decent results. The manual for the mixer will show the typical studio connection with a suggested audio interface.
Yep! Get a decent audio interface that attaches to the PC with a USB connection and uses BALANCED lines to your mixer. I use a UA-25EX Roland/cakewalk as an example. (about $200 and there are cheaper units such as M-Audio Fast Track MKII ) Note these interfaces BOTH record and playback with two channels for stereo.
Essentially the audio board that is in PC's and Laptops are too near the switching noise of the processor and some of that is just bound to get into the audio lines as they don't even have balanced audio lines from the computers. Make sure you use either TRS or XLR balanced cables from whatever interface you get. Also connect ALL interconnected equipment to the same power source or receptacle. You can try to reduce the buzz with the mixer EQ's with what you have, but that sacrifices audio quality.
It is likely you do not have the levels set correctly and are over driving the mixer. Reduce the trim settings using the PFL buttons and monitor the level indicators to insure you are not clipping.
With a condenser mic you CANNOT have any speaker in the room that the mic can hear of course. These mics are so sensitive. Your mixer and monitor speakers and recording will be in a separate room from the soundproof studio typically.
To monitor the system anywhere in the same room as the mic you MUST use headphones that do NOT leak sound or you will get feedback and distortion.
DO NOT connect your in-ear monitors to the power amp out using the MAIN/Mon speaker option as it would be goodbye hearing and fried ear buds..
Get a very small and in-expensive headphone amp and connect its input to the 1/4 inch Monitor output jack.
This particular mixer offers a usb (2 channel connection) that can be simply plugged into the computer usb 2.0. These channels should be available in Sonar from the channel Input/output drop boxes. You may need to restart Sonar, the mixer or both for them to be recognized. You may also need to run the Wav Profiler in Sonar. Typically the Wave Profiler is found in the Options>Audio menu but may be different on each edition of Sonar. The above info is for Sonar 7.
If you are wanting to record several channels at once then I would recommend connecting your Mixer's Direct Outputs from each channel to a corresponding input of the soundblaster if your soundblaster supports multiple channels. And then use the usb outbut from the Sonar to monitor the computer playback of your master stereo channel. Or, you may connect the soundblaster outputs to unused channels of the mixer or to the tape return or auxilary inputs to monitor the computer playback on the mixer.
Alternately you can send the signal to your soundblaster via the buss outputs. This will limit the number of simaltanious output channels to the number of busses on the mixer, but you can send any mixer channel to any buss without unplugging the instruments or mics.
Here's the link to the page where you can download the free pdf manual for this mixer. Page 14 explains the output connections and has diagrams. http://www.behringer.com/EN/Products/2442FX.aspx
