Looking for repair manual or help with problem
ok,there are 3 safety switches,(i have the same mower,i bought for 50 bucks because they couldnt start it),a seat switch in case you fall off,a brake/clutch switch,so you have to step on it to start and a deck switch,so if your deck is engaged,it wont start,if you can guarantee that you wont fall off or screw around and get your foot cut off,i will tell you how to bypass the safety switches,
pull the cover off the motor,see the single small black wire connected to the coil?not the spark plug cable,pull that wire off of the coil,now,find a switch that you can use for a shut off,connect a wire to the coil and run it to your dash,connect another wire to ground,connect each of them to either side of the switch,you will use that to stop the motor,put the cover back on,sit in seat,push in clutch and start your mower.be careful,there are no safety switches now,dont go up a hill sideways you will get killed if it rolls on you.
