Question about Coleman 1997 Fleetwood Sunridge Power Converter Pop Up Camper
Ive got a question about a 22 ft companion travil trailer
I unhooked my 22ft 1998 trail trailer from my brother outlet to his house . the batttiers to my trailer are fully charged , but now i cant use my outlets in my camper . why
  • 1,162 Answers
Check the fuse panel.
Posted on Jul 20, 2017
    Top Expert:
  • Coleman Master
  • 65,332 Answers
Plug it back in to the house electrics .then search for the inverter on the trailer .
Posted on Feb 15, 2017
6ya staff
SOURCE:
I need to find out at how much lbs I would tighten the head blots on a 05 gmc envoy, motor size 4.2
1st step torque 22ft lb, 2nd step tighten an additional 155 degrees per haynes manual sequence.
Feb 04, 2018 | GMC Cars & Trucks
How to replace oil; cooler on this year
  • Service and Repair
Oil Cooler Replacement
Removal Procedure
  1. Raise and support the vehicle. Refer to Vehicle Lifting.
  2. Drain the engine oil and remove the oil filter housing.
89116492
  1. Loosen the oil cooler outlet (1) and the inlet (2) lines from the engine block.
  2. Lower the vehicle.
  3. Remove the intake plenum.
  4. Remove the intake manifold.
89116493
  1. Disconnect the following electrical connectors from the water crossover:
    • The engine coolant temperature sender (2)
    • The engine coolant temperature sensor (4)
84936658
  1. Remove the water crossover bolts (1).
  2. Remove the water crossover upper and lower seals (2).
84942881
  1. Loosen the upper heat shield bolts on the left side of the exhaust manifold.
89116496
  1. Remove the oil cooler outlet line from the engine oil cooler.
  2. Remove the oil cooler inlet line from the engine oil cooler.
84942883
  1. Note the positioning of the 4 seals.
84972057
  1. Position the oil feed and return,lines out of the way and secure with mechanic wire.
  2. Remove the engine oil cooler, inlet and outlet nuts (1).
  3. Remove the engine oil cooler cover bolts (2).
84942883
  1. Remove the engine oil cooler cover.
  2. Remove the engine oil cooler.
  3. Clean all sealing surfaces.
Installation Procedure
84972056
  1. Install the engine oil cooler.
  2. Apply a 2 mm (0.08 inch) bead of RTV silicone sealant, GM P/N 12346240, in the groove around the engine oil cooler cover.
  3. Install the engine oil cooler cover.
Notice: Refer to Fastener Notice in Service Precautions.
84972057
  1. Install the engine oil cooler cover bolts (2). Tighten the engine oil cooler cover bolts to 30 Nm (22 ft. lbs.).
  2. Install the engine oil cooler inlet and outlet nuts (1). Tighten the engine oil cooler inlet and outlet nuts to 20 Nm (15 ft. lbs.).
  3. Reposition the oil feed and return lines.
84942883
  1. Install the oil cooler outlet and install the oil cooler inlet lines to the engine oil cooler. Use 4 new seals.
Tighten the oil feed and return lines to 30 Nm (22 ft. lbs.).
84936658
  1. Install the water crossover:
    • Position the crossover.
    • Install the upper and lower seals (2).
    • Install the water crossover bolts (1). Tighten
Tighten the water crossover bolts to 30 Nm (22 ft. lbs.).
  1. Connect the electrical connectors at the following locations:
  1. Install the intake manifold.
  2. Install the intake plenum.
  3. Raise the vehicle.
89116492
  1. Install the oil cooler outlet (1) line to the engine block. Tighten the oil cooler outlet (1) line to 30 Nm (22 ft. lbs.).
  2. Install the oil cooler inlet (2) line to the engine block. Tighten the oil cooler inlet (2) line to 30 Nm (22 ft. lbs.).
  3. Install the oil filter housing to the engine block. Tighten the oil filter housing to 45 Nm (33 ft. lbs.).
  4. Lower the vehicle.
Dec 22, 2014 | 2001 Cadillac Catera
Loose hose or other line
Do a video Jesse and show it to us?
Oct 29, 2012 | 1998 Ford Contour
Torque setting for a 1998 ford taurus 3.0 intake manifold
TORQUE SPECIFICATIONSDescriptionNmLb-FtLb-InEngine Air Cleaner Tube Clamps1.6-2.2-14-19Engine Control Sensor Wiring Through Bolts2.5-3.5-23-30Generator to Bracket Bolt3727-Generator to Cylinder Head Bolt4835-Generator Brace to Upper Intake Manifold Bolts and Nut12-209-14-Intake Manifold Support to Throttle Body8-12-71-106Intake Manifold Support to RH Cylinder Head40-5530-40-Degas Tube to Upper Intake Manifold Bolts8-12-71-106Camshaft Sprocket to Camshaft Bolt50-7037-51-Camshaft Thrust Plate Bolt10-88Coil and Bracket to Cylinder Head Bolt40-5530-40-Connecting Rod Nut31-3923-28-Crankshaft Damper to Crankshaft Bolt125-16593-121-Crankshaft Pulley to Damper (4 Bolts)40-6030-44-Cylinder Head Retaining Bolt(1)(1)-Accelerator Cable Shield Bolts1.4-13Camshaft Position Sensor Housing Retaining Bolt2417-EGR Tube Connector to Exhaust Manifold40-4730-34-EGR Valve to Upper Intake Manifold Bolt20-3015-22-EGR Tube to EGR Valve and Exhaust Manifold35-6526-47-Exhaust Manifold Bolt/Stud20-2515-18-Flywheel to Crankshaft Bolt73-8754-64-Fuel Injection Supply Manifold to Intake Manifold8-12-71-106Throttle Cable Bracket1713-Dual Converter Y Pipe to Exhaust Manifolds34-4725-34-Crankshaft Position Sensor Bolts5-7-45-61Intake Manifold to Cylinder Head Bolt (5)(2)(2)-Main Bearing Cap Bolt75-8556-62-Oil Drain Plug11-169-11-Oil Filter Insert to Cylinder Block27-4020-29-Oil Filter to Oil Filter Adapter(3)(3)-Oil Galley and Cooling Jacket Plugs2014-Oil Level Indicator Tube to Exhaust Manifold Nut16-2012-14-Engine to Transaxle/Torque Converter Assembly Bolts40-6030-44-Torque Converter Nuts27-4620-33-Transmission Range Sensor Nut16-2212-16-Front Sub-Frame-to-Body Bolts77-10357-75-Oil Pressure Sensor16-2212-16-Oil Pump to Cylinder Block Bolt40-5530-40-Power Steering Bracket to Cylinder Head Bolt40-5530-40-Valve Cover to Cylinder Head Bolts/Studs (5)10-14-89-123Right Exhaust Manifold Heat Shield Retaining Bolts8-12-71-106Rocker Arm Seat to Cylinder Head Bolt(4)(4)-Water Outlet Connection to Intake Manifold Bolt10-14-89-123Upper Intake Manifold to Lower Intake Manifold Bolt/Stud20-3015-22-Engine Front Cover to Cylinder Block Bolt (No. 1-10)2518-Engine Front Cover to Cylinder Block Bolt (No. 11-15)10-88Water Pump Pulley to Hub (4 Bolts)20-3015-22-Water Pump to Front Cover Bolt8-12-71-106Wiring Retainer Bracket Nut20-3015-22-Valve Tappet Guide Plate to Cylinder Block10-14-89-123Ignition Coil Bracket40-5530-40-Oil Pan to Cylinder Block Bolt10-14-89-123Water Bypass Tube Nut20-3015-22-Crankshaft Pulley Bolts40-5530-40-
  1. Tighten in four steps (refer to illustration in Cylinder Head Installation for tightening sequence):
    • Tighten in sequence to 70-90 Nm (52-66 Lb-Ft)
    • Then back off all bolts 360 degrees
    • Tighten in sequence to 45-55 Nm (34-40 Lb-Ft)
    • Tighten in sequence to 85-99 Nm (63-73 Lb-Ft)
  2. Tighten in two steps
    • 20-30 Nm (15-22 Lb-Ft)
    • 26-32 Nm (20-23 Lb-Ft)
  3. Advance 3/4 to 1 turn after gasket contacts sealing surface or tighten to 13-15 Nm (10-11 Lb-Ft).
  4. Tighten in two steps:
    • 7-15 Nm (6-11 Lb-Ft)
    • 26-38 Nm (20-28 Lb-Ft)
  5. Refer to illustration in the Cylinder Head Installation procedure for tightening sequence.
Jan 10, 2012 | 1998 Ford Taurus
I need to replace a thermostat in a 2000 Chevy 2500 6.0 liter pickup
4.8L, 5.3L and 6.0L Engines To Remove:
CAUTION
The thermostat is not serviceable separately. The thermostat housing (water pump inlet) and thermostat must be replaced as an assembly.
  2. Remove the bolts from water pump inlet.
  3. Remove the water pump inlet from the water pump.
To Install:
  1. Install the water pump inlet to the water pump.
  2. Install the water pump inlet bolts.
    • Torque to: 11 ft-lbs. (15 Nm)
  3. Install the radiator outlet hose.
6.6L Engine To Remove:
  1. Before servicing the vehicle refer to the precautions at the beginning of this section.
  2. Drain the engine coolant.
  3. Remove or disconnect the following:
    • Water outlet 6.6L Thermostat housing removal gm_trk_sil25_02-04_66_therm_hous_rem.gif
    • Bolt for the fuel line bracket
    • Thermostat housing cover bolts
    • Thermostats and seals
To Install:
  1. Install or connect the following:
    • Thermostats and seals to the thermostat housing NOTE: The rear thermostat (D) has 2 vent valves. Install with the vent valves towards the rear of engine.
    • Thermostat housing cover with a NEW gasket
    • Thermostat housing cover bolts and tighten the bolts
      1. Torque to: 15 ft. lbs. (21 Nm)
    • Fuel line bracket bolt and tighten the bolt
    • Water outlet
  2. Fill the engine with coolant.
  3. Test drive the vehicle to confirm the repairs.
8.1L Engine To Remove:
  2. Drain the cooling system.
    • Inlet hose from the water outlet Water outlet and thermostat removal chevy_sub25_02-04_60_thermost_rem.gif
    • Water outlet bolts (B)
    • Water outlet (A)
    • Thermostat (C)
To Install:
    • Thermostat
    • Water outlet
    • Water outlet bolts and tighten the bolts.
      1. Torque to: 22 ft-lbs (30 Nm)
    • Inlet hose to the water outlet
  2. Fill the cooling system.
Jan 12, 2011 | 2000 Chevrolet 2500
Where is the water pump gasket or the thermostat gasket in a 2002 cadillac escalade?
Thermostat Removal & Installation 4.8L, 5.3L and 6.0L Engines To Remove:
CAUTION
To Install:
  2. Install the water pump inlet bolts. Torque to: 11 ft-lbs. (15 Nm)
8.1L Engines To Remove:
    • Water outlet (A)
    • Thermostat (C)
To Install:
    • Thermostat
    • Water outlet
    • Water outlet bolts and tighten the bolts, Torque to: 22 ft-lbs (30 Nm)
Nov 09, 2010 | Cadillac Escalade Cars & Trucks
What is the torque spec for the thermostat housing
THERMOSTAT HOUSING BOLT TORQUE IS 15 - 22 FT LBS.
Jul 11, 2010 | 1998 Lincoln Town Car
Where is the thermastat 2006 la cross
3.6L Engine
  1. Remove the heater hoses.
  2. Remove the throttle body.
  3. Remove the radiator water pipe outlet.
  4. Remove the thermostat and housing.
    NOTE The thermostat and housing are replaced as a complete unit.
  5. To install, reverse the removal procedure. Tighten the housing bolts to 15 ft. lbs. (20 Nm).
3.8L Engine
  1. Remove the fuel injector sight shield.
  2. Partially drain the cooling system.
  3. Remove the radiator inlet hose from the water outlet housing.
  4. Reposition the wiring harness from the water outlet housing stud.
  5. Remove the water outlet housing bolt and the stud.
  6. Remove the water outlet housing and the gasket.
  7. Remove the thermostat.
  8. Clean and Inspect the water outlet housing gasket mating surfaces.
To install:
  1. Install the thermostat.
  2. Install the gasket and the water outlet housing.
  3. Install the water outlet housing bolt and the stud to the water outlet housing and tighten to 20 ft. lbs. (27 Nm).
  4. Install the wiring harness to the water outlet housing stud.
  5. Install the radiator inlet hose to the water outlet housing.
  6. Fill the cooling system.
  7. Install the fuel injector sight shield.
Oct 13, 2009 | 2006 Buick LaCrosse
I want to hook up a trailer to my truck. I notice there are "extra" outlets or something at the rear. Are these there to hook to?
any extra outlets would only be used depending on how your`` trailer is optioned.do you need a brake controller?do you have back-up light?do you need to charge a second battery?these would be the only reason to need the extra plugs.
Jul 29, 2009 | 2001 Chevrolet S-10
Coleman 1997 Fleetwood Sunridge Power Converter Pop Up Camper Logo
2,596 people viewed this question
Top Coleman Electronics - Others Experts
Gil Shultz
ray gallant
ray gallant
txslim55
txslim55
Are you a Coleman Electronics - Other Expert? Answer questions, earn points and help others
