SOURCE: Crosley Front Load Washers FL Error
Flood Condition F L “FL” flashes if any overfill condition occurs. This condition occurs when excessive water in
the tub causes the overfill switch to trip. The control must realize that the trip was due to an
overfill condition instead of a suds lock condition in order for “FL” to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out.
The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch
resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
SOURCE: FAFW3577KWO washer-code E11
Your machine may have short circuit with the inlet valve since you are facing problem after 5 to 6 mins you are suppose to change the inlet valve
SOURCE: Water will fill into my Crosley front loader
Use a putty knife to open the top lid and fold it back. Locate the lid switch. Unplug the washer. Remove the wires from the lid switch. Use a volt meter set for continuity and test the lid switch terminals. If they are open,no reading replace the switch. For a test you can jump the lid switch wires together,set the washer to spin and turn it on. If it spins it confirms a bad lid switch.
Copy and paste this link for a lid switch picture.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-cw5000-%3d%3di1456&PartID=1456
SOURCE: MY CROSLEY FRONT LOADER WILL
Hi OE error means that the water is unable to drain completely and the
bottom front access panel has to be taken apart and then the drain pump-filter
assembly should be cleaned. Hope this helps...please post back for further
assistance. Daniel
SOURCE: Error E11 on Front loader
posted at least twice on this site ,16 jan and again 2011 ( clothes stuck in machine)
Thank you for your post, derek dion!
From the information you have provided you need to know how to access the drain pump on your Crosley washer. I was unable to locate a step by step instruction sheet on how to access the drain pump. From your parts manual you would need to remove the front panel and it is located directly under the drum. If you are having trouble locating it or removing the front panel I would recommend contacting a professional technician for proper disassembly and repair. Best of luck! -OOS
Hello paversa971 - Are you certain the error code is E12? This manufacturer does not have any E12 error code for washers. Could it possibly be E10 or E11? If so, washer may be experiencing a water fill issue.
Opened the water valves fully but cant clear the code
Since we don't have this here in the USA hard to find info on it. We are a USA (Calif) website.
It is in the USA?
