Refrigerators Logo
Posted on Jul 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The bin arm on my Uline Model 402 ice maker broke off. I have a replacement bin arm. I took off the front plate of the ice maker unit, but am unable to thread the bin arm all the way through the bin arm opening. I can get it to the last 90 degree turn, but cannot go further because the bin arm which is already through the opening is blocked by the ice making tray. Is there a trick to threading the bin arm through? Do I have to take the assembly apart and separate it from the ice tray portion of the unit?
Anonymous
Level 2:
  • Expert 286 Answers
  • Posted on Jul 20, 2009
Anonymous
Expert
Level 2:
Answers
286
Questions
0
Helped
114226
Points
558
1st remove the icemaker from the unit. Then take the faceplate off.You might find that the support housing is fighting you.You should be able to move the arm into place as long as the icemaker is out.
  • Anonymous Jun 29, 2013
    I can move the arm up but it won't stay
Have replaced the 3part inlet water valve for our fridge freezer. Water is working fine,but still not making ice.
Check the ice bin level arm (also the ice maker on/off switch) is in the down position. It senses when the ice bin is full and turns off the ice maker until some ice in the bin gets used. It can also be lifted into the up position to turn the ice maker off.
Ice maker keeps making ice, does not stop when bin is full
the ice maker should have what is called a bail arm that is what measures the ice in bin if there is one it should only move up and down if it moves any other direction the bail arm post could be broken
Wiring digram for under counter uline ice maker
It is on the back of the machine, if you have clear ice maker, it may be on the back of the front plate.
1helpful
Icemaker in refrigerator won't stop making ice
Hi...
To fix your problem you need to check the shutoff arm.
An arm extends away from the ice maker over the ice cube bin. During each ice making cycle, the arm rises up and then drops back down after the new ice is dumped into the ice cube bin. As ice accumulates in the bin it prevents the arm from dropping back down. When the arm is high enough, the ice maker shuts off and no more ice is made until the ice level in the bin drops.
The ice maker can also be turned off manually by lifting the arm all the way up into a locked position.
The arm is supported at one or both ends. One end extends into the back of the front support. If it is not securely in place, it could cause the ice maker to malfunction. Confirm that the arm is securely in place.
For proper operation, confirm that arm is in the lowered position and that nothing is blocking it from normal movement.
To test the shutoff function, lift the arm up into the manual shutoff position. Recheck the unit later to confirm that no ice is being made.
Test the shutoff switch.
There are two types of ice makers, those in which all of the parts can be individually replaced and those in which some of the parts are clustered together into a control module. To determine which model you have remove the outer face plate. If there is knob, pull it off first, then pry off the face plate with a small screwdriver.
Modular units have holes in the module's face plate for test probes. If you see several holes, each marked with a letter, it is a modular unit. Component units usually have exposed gears and don't have holes for test probes.
Modular units do not use a separate shutoff switch. Instead follow this link to view instructions for checking the shutoff arm.
The shutoff switch (labeled "A") is located near the shutoff arm (Labeled "B"). Remove the switch by removing the two screws that hold it in place. The switch is connected by three wires. Label the wire placement on the switch before disconnecting the wires. The wires are connected to the switch with slip-on connectors. Firmly pull the connectors off of the switch terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced
Test the switch for continuity using a multitester. Set the multitester to the ohms setting X1. Touch a probe to the side terminal. Touch the other probe to one of the two other terminals. The reading should be either infinity or zero. With the probes still in place, depress the switch. You should now get the opposite reading.
Keep the first probe on the side terminal and move the other probe to the second terminal. The test results should be the opposite of the first terminal. If you had a reading of zero on the first terminal, when the switch was depressed, you should get a reading of infinity on this terminal.
If the switch fails either test, it should be replaced.
Hope it is helpful for you
Thanks for using fixya
Ragards
ICmanServer
Wiring came unplugged need wiring scematic for uline ice maker
wiring diagram is on the back of the machine. If you have clear ice maker it may be on the back of the front plate.
Ice maker overfill
The metal off/on arm may be disconnected. A full bin should keep the arm in the up position and shut off the ice maker.
Remove, then re-insert the metal arm in the back of the ice maker control head.
Make sure that a full bin of ice activates the control arm.
You may need to buy a replacement arm that is longer so that the ice catches on the arm.
Uline icemaker must be manually prompted to rotate and drop cubes
If your looking for a icemaker it should be part 402. Call U-line with the serial or model number to be sure they made it.800-779-2547
1helpful
2answers
Ice maker won't shut off when full
check the Shutoff Arm:
The ice maker can also be turned off manually by lifting the arm all the way up into a locked position (shown belowef280e4.jpg
The arm is supported at one or both ends. One end extends into the back of the front support (see photo above). If it is not securely in place, it could cause the ice maker to malfunction. Confirm that the arm is securely in place.
If unit continues making ice even when the shutoff arm is in the up (off) position, refer to the diagnostic table or for a modular ice maker, replace the control module.
check the Shutoff Switch:
Before testing the shutoff switch, unplug the refrigerator to avoid an electrical shock hazard.
Modular units have holes in the module's face plate for test probes. If you see several holes, each marked with a letter, it is a modular unit. Component units (like the one shown below) usually have exposed gears and don't have holes for test probes.
Modular units do not use a separate shutoff switch. Instead follow this link to view instructions for checking the shut off arm.
Uline ice maker not cool enough to make/keep ice
one of two things
1. fan under unit stopped up or quit
2. small freon leak usually in freeze plate
1helpful
2answers
BI-95 ULINE
raritan eng/whirlpool ice maker assembly
Top U-Line Refrigerators Experts
Kardoc
Jorgie  the...
Jorgie the...
ADMIN Andrew
ADMIN Andrew
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
