Question about Maytag EPIC MFW9700S Front Load Washer
The door has too much play in it. You have to lift it up about 1 1/2 inches to be able to close it and obviously something is too loose in the hinge area but I don't know how or where to tighten it
2 Suggested Answers
6ya staff
SOURCE:
canbruce75
Bruce Canfield
  • 1776 Answers
SOURCE: Door broken at hinge area on Maytag front load washer 24".
Try using some J.B. Weld on it instead of glue. It will essential form a weld and should hold up better. You might want to give that a try. Good luck and best wishes.
Posted on Aug 05, 2009
How do I put in my oven door?
The door on k.a. / whirlpool - hinge has a tab that locks rhe hinge and prevents the hinge spring from pulling door closed all the wayslightly lifting and continuing to close thw door lifts it off the hinge rest. Some models have set screws that need to be removed some require door disasembly some ge maytag frigidaire dcs wolf viking etc the door simply lifts off. The hinges stay attached to the app.and some have holes at the pivot of the hinge wherea 1/8 inch metal tabs or nails are inserted and door is ifted up and out....
(That is 1/3 of the job 2/3 is puting it back) lol
Mar 09, 2015 | Kenmore 75012 / 75014 Gas Kitchen Range
Washer door drops when i open it.when i close it i have to lift door. hinge seems loose
This may seem obvious, but tighten all the screws on the front panel, especially around the door hinge area. A #2 Phillips screwdriver is all you need. Also, try to see where it's dropping - is it at the door itself, or does the entire hinge assembly sag where it enters the washer?
Jun 21, 2014 | GE WCVH6260FWW
Right door no longer closes all the way by itself
If you're loading up the door with a large amount heavy items such as gallons of milk, water, juices, etc. - the door may be sagging on its hinges.
Typically, there are several screws that hold the top and bottom hinges to the fridge frame. While supporting the weight of the open door with blocks or books, check to see of the screws have loosened up or if the hinge has slipped on the fridge cabinet. It may be helpful to partially / fully unload groceries / liquids from the door.
You may be able to detect that something has happened if there is space between the top hinge and door. This suggests that the door has slipped slightly and may be rubbing on something. Look for scrapes, scratches and filings in the area of the bottom hinge. These are a tip off that something has changed. Try lifting the door up. Is there "play" between the hinges that allows the door to slide up and down? A little bit is normal, but too much indicates a sagging or bent (not common) hinge. You may have to lift and support the door to take up the "play"; then loosen the bottom hinge's screws and slide the hinge up until it is snug against the bottom of the door. Tighten the screws firmly to hold the hinge in place. This should lift the door back to where it was (or close to it) and prevent any rubbing or scraping that may have been happening before.
Lastly, make sure that the doors seals haven't shifted or become damaged in such a way as to interfere with the door closing completely. Good luck!
Feb 14, 2012 | Frigidaire FRS23R4A Side by Side...
Hi the right hand hinge of the door has popped out whilst I was trying to move the oven using the door handle as leverage. The door is now wonky when closed as the hinged has popped out. Help!
All oven door typically lift off the hinges by design. If you open the door to what is referred as the broil position. You know when the door stops about 4 to 6 inches open at the top. Then do the following.
1. Lift the door up completely off the opposite hinge still in place and remove. Set the door aside carefully as if has glass window, you do not want to break.
2. Then set both hinges at the broiler stop position. If one is all the way in to door fully closed position pull it out with your hand or with pliers till it stops @ broiler position. If all the way down as if door was fully open, lift hinge until it stops at broiler position. CAUTION- THE HINGES ARE SPRING LOADED AND CAN SNAP BACK INTO FULLY CLOSED POSITION. You can use a heavy glove or if you have an oven mitten, that can work to protect your fingers. DO NOT GET YOUR FINGERS BETWEEN HINGE AND OVEN OR CAN PINCH FINGERS.
3. Now carefully lift the door over the hinges set at the broiler position. Careful not to bump them when doing so or can snap closed. If does, reset hinge to broiler position and repeat. Works best to hold door at angle that door is when in broiler position. Once you have them started evenly, you should be able to fully slide down back onto both hinges.
4. If one of the hinges no longer has spring tension you have to reattach the spring. You can usually access spring if needed by removing the bottom drawer.
Aug 27, 2011 | Ovens
The hinge to close the oven door came loose from the oven how do we fix this
Oven doors detach by lifting. take the door off and it should be obvious what to fix. Be careful when handling the hinge as it has a strong spring and can give your fingers a real wack.
Jan 04, 2011 | Whirlpool Ovens
GE Oven door lock 'engaged' while door was open and door will not close - how do I release the lock?
If your oven door has gotten bent or warped (maybe you rested something heavy on it...), you need to remove the door, disassemble it, and straighten it. You can lift most oven doors off of their hinges by opening the door several inches to its first "stop," and lifting the entire door straight up. If the hinges have become worn, damaged, or bent, you probably need to replace them. We recommend replacing both hinges at the same time, to prevent uneven wear of the undamaged hinge.
Dec 06, 2010 | GE JTP27 Electric Double Oven
My oven door doesn't close completely. Is there a way to adjust the door?
Hi There
I found this for to read so you can fix your door.I hope this will help you.Let me know how it goes.
The oven door won't close If your oven door has gotten bent or warped (maybe you rested something heavy on it…), you need to remove the door, disassemble it, and straighten it. You can lift most oven doors off of their hinges by opening the door several inches to its first "stop," and lifting the entire door straight up. If the hinges have become worn, damaged, or bent, you probably need to replace them. We recommend replacing both hinges at the same time, to prevent uneven wear of the undamaged hinge.
Thank you for writing to fix ya.
Best Regards Richard
Dec 30, 2009 | Ovens
Frigidaire gallery microwave door sags
Repairing the loose, detached hinge is simple.
First buy a pop rivet tool and 1/8'' or 3mm rivets for about $16 at lowes
Second remove the door. There is a little plastic pop tab on the inside top corner of the door by the hinge that keeps the door from lifting off of the hinge pins. Use a 1 inch putty knife or maybe a butter knife and pry from the bottom crack. Once tab is off the entire door can be lifted off.
Third, line up the little holes in the bracket with the little holes in the microwave face. Insert a pop rivet in the hole and squeeze the tool till it pops off. I put one 3mm rivet on the top hinge and one on the bottom.
No drilling needed on my Fridgidaire PLMV169DCd microwave. I guess u could drill a 1/8'' hole thru the microwave face and the hinge bracket if there isn't one on your model.
Mar 10, 2009 | Frigidaire GLMV169D Microwave Oven
Bottom hinge on fridge door broken
Yes, there is supposed to be a plastic bushing/washer under there. Usually 1/8 inch thick. If a dealer is not handy you may cut some out of plastic to put there. Then undo the top hinge, and carefully lift the door off (you might want to empty the shelfs). Put your spacer on the hinge pin, and replace the door and the top hinge.
Jan 28, 2008 | Liebherr Premium CTP 3153 Top Freezer...
Loose microwave door
My over the range microwave had a loose door, it sagged when it was open but you could lift it to close. Called repair person he said no it could not be fixed. You could see the bottom hinge was loose and slipping. I loosened 3 screws that holds the bottom on the microwave -you have to do this to change the light bulb also. The bottom hinge on the door was loose there was a hole there, so took a screw and nut to hold the hinge in place..I am a 70+year old woman-if I can you can.
May 14, 2006 | KitchenAid KEMC377K Convection / Microwave...
Maytag EPIC MFW9700S Front Load Washer Logo
50 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
