Question about Husqvarna Rz5424 Zero Turn Lawn Mower Kohler Courage Engine
How do I bypass the brake switch
If the brake is on it won't start , and it has to be jumped thru the seloniod
    Top Expert:
  • Husqvarna Master
  • 85,216 Answers
Follow the shaft/arm that the brake pedal is attached to, the switch will be activated by that pedal arm.
Posted on Oct 31, 2016
6ya staff
SOURCE:
How do I bypass the seat safety switch on a 5424 Husqvarna zero turn mower?
ether unplug it if wont start then jump the wire pigtail with a wire you can bypass both switch like this
Sep 16, 2014 | Husqvarna Rz5424 Zero Turn Lawn Mower...
2002 chevy impala won't start if I jump starter
Is the security light on or flashing ?
The yellow wire goes from the key switch to the neutral safety switch, then to the starter. So bypassing the neutral safety would make the starter crank the engine, but would have nothing to do with the rest of the engine.
May 27, 2013 | Cars & Trucks
Wont start just click.
Even after charging the battery or jumping? Do you know where the starter is located and what it looks like? Round, 3 wires coming out of the top, located under the engine at the rear. Check these wires and make sure they are secure. Located on top of the starter is the selonoid which causes the starter to engage. With the vehicle in park, emergency brake applied, have someone try starting it while you lay underneath. Listen for a clikcking to come from the seloniod. Can put your hand on it and feel the click too. If you get a strong click, but the starter does not engage, you may have a bad starter. Not too hard to change out but take battery cables off 1st! Also change the seloniod if you take the starter off. You do not want to do this twice so easier to make sure both parts are new. GT
Apr 22, 2013 | 2007 Chevrolet Uplander LS Minivan
Wnt start
There were concerns about lurching on start-ups and the Manufacturers developed safeguards to prevent this. On some manual transmission models there is a safety switch on the clutch pedal lever. On automatics, it is a switch on the Brake pedal lever.
Sometimes named the "Boo" switch, it sends a signal to complete the starter solenoid circuit. You will notice the Brake lights are out on the automatic models.
Without this signal, the starter circuit will be quite dead. It is common to be broken or misaligned when a Drivers' foot hits this switch. As for the green/purple wire-free wiring diagrams are available from Autozone.com when you register with their site. Their site has both free and pay info at the bottom of their Homepage help section.
Please rate my info.
Mar 05, 2013 | Ford F-150 Cars & Trucks
Pto wont work
try and bypass the safety switch on the clutch/brake pedal
Apr 11, 2012 | Garden
Have a Husky yth180 mower. Battery was going bad and wouldn't start so I jumped it to finish mowing. Replaced battery and still won't turnover. Jumped starter and does turnover. All switches...
hi there dolson894
here is web site for owners manual
http://lawnandgarden.manualsonline.com/manuals/mfg/husqvarna/yth180.html
download owners yth180 manual it has a wiring diagram in it - may help
sounds like a starter solenoid problem, check for good grounding of the negative bat cable and grounding of the solenoid to the frame , check for 12 volt at the solenoid tab ( not the heavy contacts)
this wire solenoid tab wire comes from the S marked terminal from the main switch and power from the battery is taken from the HOT post of the starter solenoid up to the B terminal of the main switch, from there when contact made between B + L + S @ SWITCH voltage sent to solenoid for start
basic connections for switch in start mode is B + L + S
run / light B + L and Makes A + Y
run B + L off G+ M +L
check seat switch and brake switch - bypass with jump wire if need
across white to wjite wires on brake switch
see what hapens , the try a jump wire across the seat switch wires green to green and retry
if stil no good - replace solenoid as you mentioned with a jump cable straight on start motor turns over good
check out website
cheers hope it helps pauly46
dont forget the thumbs rating
Jun 07, 2011 | Husqvarna Garden
I have a 94 Jeep grand Cherokee and I can't shift from park to any other gear. It seems to be locked.
Theres a shifter lock, this is so the trany cant be shifted unless your foot is on the brake, the most common problems are the brake light switch is bad or the fuse blew. Have someone look at the rear and see if the brake lights come on when you step on the brake pedal if the lights dont come on then check the fuses , check all fuses then look under the dash where the brake pedal is and look for the brake switch, this is located on the bracket for the pedal, so if you follow the pedal up you will see the switch. check the connector to this brake light switch and make sure its on good. If the connector is on and the fuses are good then you may have a bad switch, unplug the switch and jump the two connector, this is what the switch does except you will bypass the switch by connecting the two wire at the connector to the switch together the brake light should come on and then try shifting. now if when you stepped on the pedal the lights came on then the switch and fuse is good and you may have a bad shifter seloniod, this is a little harder, this is located in the shifter area and gets dirty form spilled coffe or soda and other thing and makes it stick you would need to remove the covers and see. good luck, hope this helps.
Jan 23, 2011 | 1994 Jeep Grand Cherokee
18hp kohler engine (grasshopper) won't start. Single click from starter/solenoid when key turned. Battery new/charged.
I have a duetz-allis mower with 18hp. kohler eng. won't start, have new seloniod, new circuit breaker, getting fire to switch & out. Still won'tstart
Aug 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
It will not shift out of park
first is to check all the fuses, then check brake light switch, power comes from brake pedal brake light switch, when pedal is push power is sent to brake lights and power is also sent to shift lock seloniod, when this seloniod is power up it releases the arm that keeps the shifter locked. so if theres no power or a bad brake switch then the shifter wont unlock,so start with the fuses then the brake light switch, hope this is helpful.
Dec 26, 2009 | 1996 Chevrolet Blazer
Husqvarna Rz5424 Zero Turn Lawn Mower Kohler Courage Engine Logo
703 people viewed this question
Top Husqvarna Garden Experts
J. Bradshaw
Marvin
Marvin
dannydoesita
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
