Is there a reset button or something that will cancel this flapping noise of the dispenser, or is there a part that needs to be changed. Does the door need a washer or something that has broken
SOURCE: Ice Dispenser - in door
Yes that repair is quite common and not too difficult you need a Maytag Fountain door Kit dont have the part# hear but can be researched available at all appliance part retailers........comes with the solonoid, new flapper door and outher redesigned pieces also an instrunction sheet A solved rating is great motivation to continue giving priceless advise........
SOURCE: door flap and latch to ice maker and water
the parts you need can be found a www.apdepot.com part # 32 is door but latch / is ?? but in the diag you will be able to see what you need . hope this helps mm. . tip after reassemble try using food grade silcone on moving parts and shute this prevents freeze up .. mm
