I have pushed the power button twice and unplugged it. Still when I try to turn it on it quickly acts like it is going to run then shuts down and displays the (DO) error. Could you please help.
SOURCE: maytag neptune washer display showing FL
fl is a over fill. clean the pump out and the sump near the pump is in the back the dran hose goes to it
SOURCE: maytag dryer mde9700ayw
I have the same problem--it is the heating element. Bad news is they don't make the part anymore. The solution from maytag.com is to buy a new one and they will reimburse you 15%...not a very good solution considering how much this one cost and the amount of years it has been used.
If you find a place that sells the heating element please post!
SOURCE: NO POWER TO DRYER???
Hi there, you are experiencing a power supply board failure. this board may have used all its life up and unfortunately, it will have to be rebuilt or replaced.
SOURCE: Maytag MDE9700AYW electric dryer doesn't stop in sensor dry mode.
The link below contains the service manual. Detailed Troubleshooting begins on page 10.
Good luck
MDE9700 Service Manual
SOURCE: Maytag Neptune MDE9700AYW Elec. Dryer. Drum Not Turning
the problem is with its motherboard .. i too had the same problem.. ask the repairing persons to change the motherboard if it is warranted. ( but there is no other way)..
