Making grinding noise...and filling with cold water, I thought because it is attached to hot and cold under sink it would fill with both x
You have two water solenoid valves, one hot water and one for cold. If you switch the hot and cold water hose connections the washer may fill. If it does, the solenoid valve is defective, and you will need to order a new one and replace it. If you take off the back panel of the washer you can follow the hose to the solenoid which has wires connected to it. Did you stick a bucket under the water faucet to make sure water is actually coming out of the faucet when you turn it on?
