Apple iPad 2 Wifi 16GB Logo
L
Loretta Nelsn Posted on Sep 28, 2016
Take out charge card
Need help to take out per pack d cut card
Zeki tablet 10.1 will not charge
not familiar with that tablet but most charging problems are either the cord or battery needs replacing. If light does not come on when on charge then you need a new cord. If light comes on and it won't hold the charge then it's time to replace your battery.
I got charged for Sadie When She Died I don't have a kindle please uncharge me
You need to contact Amazon.com. If you have an account, just log in and dispute the charge. IF you do not have an account and she used your card, you should contact your credit card company and dispute the charge.
If she used her own credit card, then you need to contact her credit card company and be ready to submit a ***** certificate.
Replaced battery per instructional video and unit will not charge on factory charging cable.
if the device has not had charge in the battery you need to plug it in when red light goes off take charger out fot 3 secs.place back in and do it again in 15+minutes it WILL come on
1helpful
Won't charge a tablet
The charger might be defective and not capable to deliver the required current to charge the battery, try a replacement charger.
Why does innotab charging light blink when charging and will not charge?
the charge imdicator is suppose to blink when you plug the toy to the wall adaptor. if it doesnt blink then there's something wrong with either the adaptor, the adaptor port on the toy or the rechargeable power packs. now i said that the light is suppose to blink. but the frequency of the blinks shouldnt be fast. if that's the case clean the compartments and re-insert the batteries. if you are still having problems try the ff T/S:
1)remove the power packs, plug the toy to adaptor and turn it on. if it turns on that means your adaptor is working.
2)remove the adaptor and try using just the power packs.
3)try using 4aa batteries.
if the toy turns on with only one of the power sources stated above you better call vtech hotline.
My rca tablet wont charge
Either the power converter (wall Pack) has no output of voltage....Or the battery has run its cycle of life. Symptoms of bad battery are,will take no charge,or not hold a charge for very long, or will not charge fully.I have an IPOD that I charged fully,and then put it away for a long time, when I got it back out....it wouldn't take a charge at all. These kind of issues are common with batterys . Hope this is helpful.
1helpful
Light keeps blinking pass the 30 second mark
If it's flashing all lights fast at same time....don't worry. My mophie juicepack powestation does this all the time and refuses to take any charge. I bend a paperclip into a u shape and short the pins in the usb output Jack for not even a second. Quick touch is all that is needed. NO LONGER OR RISK DAMAGE OR FIRE. Resets the chip inside. Charges fine then.
Zeepad still freezing i want to keep it, i just followed instructs in box, charged it, held power down for three minutes, and now recharging for two hrs. any tips, i don't like returning things i purc
Upon first use, you have to charge the battery overnight. Then for every recharge, you may have to keep it connected to the charger for at least 4 to 6 hours depending on your tablet, otherwise, your battery will go kaputt in a short period of time.
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
