Washing Machines Logo
Mario Rodriguez Jr. Posted on Sep 28, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Everytime I start the washer it pauses halfway through the cycle why is that
baylon nkeshimana
Level 2:
Sergeant:
  • Expert 182 Answers
  • Posted on Sep 28, 2016
baylon nkeshimana
Expert
Level 2:
Sergeant:
Answers
182
Questions
0
Helped
59615
Points
582
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design. Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design. Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer
3 Related Answers
Anonymous
  • 449 Answers
  • Posted on Sep 19, 2008
SOURCE: F11 code flashing-washer stops
hi!!!!
try to unplug it end then check the control timer if it is broken !!!!
or open it if you know and fix it may be the spring that pull back the pause botton
might be broken go check it?
Anonymous
  • 5081 Answers
  • Posted on Oct 03, 2010
SOURCE: The washer will not start
Is there any light named CONTROL LOCK light up on the control board?
mikes112
Michael Schaffter
  • 57 Answers
  • Posted on Jun 23, 2011
SOURCE: Washer pauses at various times during the cycle
Did you find a solution? Mine just started doing the same thing.
How do I soak items overnight in my LG WT517OHW washer
  1. Load the items you want to soak into the washer drum.
  2. Press the "Power" button to turn on the washer.
  3. Press the "Pre Wash" button, this will start a pre-wash cycle that will last for 5 minutes, this will give you the time to add any detergent or laundry pre-treatment solution.
  4. Press the "Start/Pause" button to start the pre-wash cycle.
  5. Press the "Delay Start" button to set the time you want the washer to start the main cycle. This will give you the opportunity to soak the clothes overnight
  6. Press the "Start/Pause" button again to start the main cycle after the pre-wash cycle is complete.
  7. Leave the items in the washer overnight.
  8. In the morning, press the "Start/Pause" button to start the main cycle again.
  9. When the cycle is complete, unload the items from the washer and dry them as usual.
  10. https://www.lg.com/in/support/video-tutorials/CT20150045-20152230657216
MAYTAG WASHER 2000 SERIES E1F6 CODE COMES UP OLUTION PLEASE
"LF" on display (Long Fill - no water or insufficient water supply) Press POWER/CANCEL to cancel the cycle. Unplug washer or disconnect power.
Plug in washer or reconnect power. Re-select cycle and press START/PAUSE. "F9E1" on display (Drain Problem) Press POWER/CANCEL to cancel the cycle. Unplug washer or disconnect power.
Plug in washer or reconnect power. Re-select cycle and press START/PAUSE. "SD" on display (Suds Routine) When excessive suds are detected, a suds routine automatically starts. This routine removes extra suds and assures proper rinsing of your garments. "SD" is displayed during rinsing and at the end of the cycle to inform you that the Suds Routine was activated. Use only HE (High Efficiency) detergents. "F--E--" Variables (Washer Problem) Press POWER/CANCEL to cancel the cycle. Select RINSE, DRAIN & SPIN if there is excessive water in the washer. Re-select cycle and press START/PAUSE.
My washer pauses halfway through the rinse cycle sometimes but pauses before the spun every wash have to push start numerous times during wash for it to completely wash the clothes
Possible that the main memory of the controller is corrupt and so there is fault in the program. Remove the power and remove all connectors to the board, check on all contacts and for moisture within the board. If so dry using a hair dryer.
If not the controller is a suspect. check for moisture on the customer panel
1helpful
Pause error unit will not wash
Hello cvaughn37_cv - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Whirlpool Duet washer - paused cycle to add a garment now can't get it to resume cycle or clear the cycle.
I did as Drunan did and unplug for 10 and plugged it back in and it started like a champ! Thanks!!!!!! ;)
2answers
Drum knock when spin cycle
Hello.
Noises are common when using a two-in-one washer and dryer, as clicking or whirring is part of the cleaning process during the transition to the next cleaning process. The GE Spacesaver washer and dryer combo uses a top-loading washer stacked beneath the front-loading dryer, and uses an agitator that makes noises throughout the spin cycle. Although whirring or clicking is normal, other noises or malfunction indicates a problem with the washer that requires minor troubleshooting. Professional repair is necessary if the washer continues to experience problems during the spin cycle, as there may be a problem with the washer's agitator.
1 Open the washer's door and check the balance of the load's clothes. Clothes that are unevenly distributed around the agitator cause excessive shaking and result in an imbalance during the spin cycle. Reduce the load's size by removing clothing if the washer's drum is overloaded.
2 Push "Start/Pause" to pause the spin cycle and turn the washer's cycle knob to the "Off" position. Turn the knob to "Spin Only" and press "Start/Pause" to reset the cycle.
3 Turn the wrench counterclockwise or clockwise around the unit's legs to adjust the appliance's balance. The legs are adjustable with the help of a wrench to ensure the unit does not shake while in use. An unleveled unit shakes as it spins, and causes excessive squealing or rattling as it attempts to dry the clothes.
4 Touch "Start/Pause" on the front of the washer's control panel and unplug the washer/dryer unit's power cord from the electric oultlet. Wait two minutes and plug the power cord back into the electric outlet. Push "Start/Pause" to resume the spin cycle.
Thanks.
2helpful
2answers
Washer stops after it fills and won't start again
Hi, you need a new lid switch. If you could get me a model #, I could get you exact info on the part and instruction.
please let me know if I can assist you fyrther.
Vic
Reset wash cycle
Changing Cycles, Options and Modifiers
Not all Options and Modifiers are available with all cycles. Cycles,
Options and Modifiers can be changed anytime before HOLD TO
START is selected.
Options and Modifiers can be changed anytime after HOLD TO
START is selected and before the start of the selected Option or
Modifier.
To cancel a cycle and select a new cycle
1.
Select PAUSE/CANCEL twice.
2. Select desired cycle.
3. Select the desired OPTIONS.
4. Select HOLD TO START (for approximately 1 second) to
restart the washer at the beginning of the new cycle.
To cancel a cycle
1.
2. The washer powers down, the door unlocks, and clothes can
be removed.
NOTE: If the water level or the temperature is too high, the
washer will drain automatically before the door unlocks.
To change Options or Modifiers after the cycle has started
1.
Select PAUSE/CANCEL.
2. Select the desired OPTIONS or MODIFIERS.
3. Select HOLD TO START (for approximately 1 second) to
continue the cycle.
To drain the washer manually
1.
2. Select DRAIN/SPIN.
begin the drain.
4. When the spin is complete, the door unlocks. Items can be
removed from the washer.
Top Washing Machines Experts
john h
