I have a freezer true 2 doors but i want to converter frigirator so i need all the steps so i can try >>
Before you do, consider these items:
1.) You will need to replace the compressor (Most likely). Compressors are sometimes rated for medium and low temp applications but not always.
2.) You may also need to replace the evaporator. They are rated by BTU's and what you have most likely will not work as you are changing the temp range.
3.) You will need to disable the defrost control and heater.
4.) You will need to bypass the fan delay or remove all together and reconfigure the wiring for such.
5.) You will need a new expansion device. Be it a cap tube or TXV, it still needs replacing as you are changing the temp range and BTU's you want.
6.) You will most likely need to replace the temp control (t'stat). Again, different temp range.
7.) Now, figure in the labor it takes to do all this. (Including the research to see it these items will work or not.
You may want to rethink doing this and opt for another piece of equipment.
Anyway, these are the steps you will need to take if you want to do the conversion.
Hope this has been of some help.
