Washing Machines Logo
irene newman Posted on Sep 22, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Just purchased 2nd hand Miele novotronic w310. Does machine automatically stop? Cycle ends, anti crease light on and machine just tumbles clothes makes odd noise, then tumbles again. Is the normal?
BOB LEA
Level 2:
Guru:
  • Expert 62 Answers
  • Posted on Sep 22, 2016
BOB LEA
Expert
Level 2:
Guru:
Answers
62
Questions
0
Helped
15417
Points
257
NORMALLY WHEN A DRYER COMPLETES IT'S DRYING TIME IT WILL GO THROUGH A COOLING DOWN CYCLE,
DRYER WILL START TURNING WITH FAN ON ONLY FOR A FEW SECONDS THEN STOP, AFTER A SHORT PERIOD IT WILL DO IT AGAIN AND AGAIN UNTIL UNIT HAS COOLED DOWN, HOPE THIS IS WHAT YOU ARE EXPERIENCING
GOOD LUCK
  • irene newman
    irene newman Sep 25, 2016
    This isn't a drier it's a washing machine
5 Related Answers
Anonymous
  • 16 Answers
  • Posted on Feb 08, 2008
SOURCE: Miele Premier novo washing machine
Flashing rinse light is a drive fault. No motor action. If it's an earlier model it would be the motor brushes. Later model will be the electronic which controls the motor.
Anonymous
  • 16 Answers
SOURCE: Miele Washer problem Novotronic Premier
Main wash light flashing is a heating fault. You either have a faulty temp sensor (NTC) or the pressure chamber has blocked and the heater element has popped.
Anonymous
  • 3587 Answers
  • Posted on May 10, 2008
SOURCE: water not getting into washing machine miele novotronic w830
K5? which pipe is that..let's assume you have pressure to the back of the unit, yes? then you have a valve sticking or something obstructing the channels inside that unit..
does this work regardless of temperature setting.
Anonymous
  • 70 Answers
  • Posted on Jul 26, 2008
SOURCE: Miele novotronic w820
i havent changed one on this model but there useally much the same and qiute easy to do first take the back off the machine
at the lower half of the rear of the drum there is two prongs sticking out with wires on spade connectors a third earth wire in the centre remove these 3 wires they should just pull off but sometimes held on by nuts you will have to check yours then with the machine emty of water unbolt this is the element assembly is the reverse
Anonymous
  • 297 Answers
  • Posted on Apr 16, 2009
SOURCE: red light flashing
red light is check drain?
Clogged by something.
Could be a coin.
Use to have large coin when i was young and forgot remove from my jeans. So mum made me repair that every time. In that case filter clean, but coin bloking filter inlet.
Not necesarily coin in your case.
never buy these deals over Ebay my advice.
If you have the machine already then this is first to look for.
The dryer is showing anti crease on the LCD. What can i do to reset or fix the problem.
have you tried disconnecting the power for about 15 minutes to see if it clears
anti crease refers to the dryer continuing to tublme for about 10-15 seconds every 5-10 minutes so when cycle is complete the clothing doesnt just set there where wrinkles can set in ,it tumbles after end of cycle to prevent wrinkling
2helpful
Red light flashing
Could be a coin.
3answers
Top Miele Washing Machines Experts
Paul Carew
vince
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
