LG 42LC2D 42 in. LCD HDTV Logo
David Haygood Posted on Sep 20, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tv shows screen briefly then goes black - LG 42LC2D 42 in. LCD HDTV
Level 3:
Top Expert:
  • LG Master 76,851 Answers
  • Posted on Sep 21, 2016
LG Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14987045
Points
237762
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
How do I get Amazon Fire TV resolution set so I get more than a blue screen?
Select the input channel for your Fire TV - Turn on your TV and select the input channel for the HDMI port you used to connect your Fire TV. You should then see a loading screen with the Amazon Fire TV logo 4.
I think my htmi port is faulty i have tried 2 different leads n in both ports i can see whats plugged in briefly but then the screen goes black n red briefly n goes blue n stays blue
It may be necessary to change the input selection via the TV's menu system from its current setting to HDMI.
A blue screen is often used to indicate 'no signal.'
My hannspree tv screen goes black blank
If the picture shows a picture briefly upon power up then goes off after a few seconds, you have a back light fault. It could have a problem in the 24vdc circuit, failing back light inverter board, or a blown CCFL lamp.
1helpful
ASUS EeePC 900A- black screen blinking cursor
The hard drive has issues, or the window files are corrupt. I suggest a computer repair store to retrieve files and test hardware.
The tv briefly powers up shows the memorex logo and then the screen goes black no picture, but stays powered up. And will not allow or show any functions please help
The poroblem can either be the 12~18vdc power supply section is not supplying the power to the backlight inverter board or the inverter board went out, you need to check voltage on the power supply, also look to see if you see any caps with leaking/bulging top.
See example of failed TV and monitors here:
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Picture only works briefly
change your backlight inverter
Dell Latitude cpx
Symptoms of a Bad Video Driver
Monitor Resolution issues:
screen flickers, screen is cloudy, screen shows horizontal lines, screen goes black, goes blank, goes into sleep mode, goes into power mode, size magnifies or reduces, video is jittery, fonts change, screensaver will not appear, cannot extend display on dual monitors.
Download it from here
VIDEO DRIVER FOR LATITUDE
Black Rectangle Appears on Screen
Perhaps the caption is on?
Help
Not a home repair take it to a repair store.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
