You would have to know a little about electrical repairs, if you don't then I suggest finding someone who does because the repair can present electrical dangers.
Some might say to splice the cable around the cut, but I'm not one of them. If the power wire comes from the inside of the TV then you can usually open up the back of the TV and replace the wire with a little soldering. Make sure the wire you use is properly rated for a standard house appliances. (lamp/etc.) If the wire instead simply plugs into the back of the TV then you may just have to contact the manufacturer (or electronics store) to get a replacement wire.
SC305. Occurs after replacing charge corona unit. Answer [Cause]
PCU-side quenching lamp has come loose from bracket. [Action]
Return quenching lamp to correct position.
The Lamp light of the TV blinks when the Lamp in the TV requires replacement.
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue. Follow the steps below to perform a power reset: Try the following steps to check if the issue can be resolved. Turn off the television. Unplug the television power cord from the electrical outlet. Let the television remain without power for 60 seconds. Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, re
This tv has a faulty connection to the temp sensor that sits behind the lamp. You can purchase a improved one from Mits or get it repaired, or do it yourself. You will need to pull off the back and remove the lamp and the fan airduct to the right (3 screws i think) and you can get access to the sensor. It is held in with a screw that points toward the back of the tv and the sensor sits on the other side of the metal from the lamp. The connector to this sensor is faulty, so you can pull it out and just cut off both sides of the connector and hard wire it with some solder, or just twist it up really good and tape it up with electrical tape.
The early versions of the lamp had a very fine screen on the lamp housing, this clogs easy, it may be clogged causing your issue as well. Pull out the lamp and look for the small screen. Clean if necessary. If its very fine and clogged, you may just want to remove the screen completely to prevent further issues.
hi im jules_09.
sc 401 means transfer roller leak error.a transfer current leaksignal is detected.posible causes is 1.transfer power pack is defective 2.poor connection between the transfer terminal and the trnsfer power pack
sc 419 mean quenching lamperor.1 quenching lamp defective 2.poor conection between power pack and quenching lamp.
check all component but pay attetion to the current leak at the transfer because there both connected at the power pack
