Electrical Supplies Logo
jaspreet Canada Posted on Sep 13, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Upon starting the forklift error code -30 is displayed and the it does not go forward or backward - Clark forklift model TMG20
Upon starting the forklift error code -30 is displayed and it does not go forward or backward - For Clark forklift model TMG20
  • Merlin Oct 28, 2016
    Somewhat yes. It will shift through the gears . Like some locked the brakes
Merlin
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 28, 2016
Merlin
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1626
Points
Somewhat , yes. Like someone locked the brakes on
Marvin
Level 3:
Top Expert:
  • Master 85,242 Answers
  • Posted on Sep 13, 2016
Marvin
Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29052104
Points
266281
Do you hear the groan of the hydraulic system?
What is the error code -031 on a clark tmx clark forklift
FAULT NAME: VMN HIGH
- FAULT DESCRIPTION: wrong voltage on power motor outputs, failure in the power section or in the mosfet driver circuit or in the motor. https://www.forkliftaction.com/forum/trouble-code-31.aspx?t=14834
https://errors-codes.jimdofree.com/clark/
Clark model FCG 32, error code 42
Error code 42 on a Clark forklift model FCG 32 indicates a problem with the fuel system. Specifically, it means that there is a problem with the fuel injection system, such as a clogged fuel filter, damaged fuel injector, or fuel pump failure. This can result in a lean or rich fuel mixture, causing the engine to run poorly or not at all. It is recommended to have a certified mechanic inspect and repair the fuel system to ensure safe operation of the forklift.
I have a forklift Clark have error code -51 what is this ?
Error code -51 on a Clark forklift typically indicates a problem with the hydraulic system. This could be caused by a variety of issues, such as a faulty hydraulic pump, a leak in the hydraulic system, or a problem with one of the hydraulic valves.
To troubleshoot this issue, you will need to first check the hydraulic fluid level and make sure it is at the correct level. If the fluid level is low, refill it to the proper level and see if the error code clears.
If the fluid level is fine, you may need to perform further diagnostic tests to identify the root cause of the problem. This could involve checking the hydraulic pump and valves for any visible signs of damage or malfunction, as well as testing the system for leaks.
If you are not comfortable performing these tasks, it may be best to contact a professional mechanic or the manufacturer for assistance. They will be able to diagnose the problem and recommend the appropriate repairs.
1helpful
2answers
I have a clark dpm20n forklift that wont go forward or backwards. Can anyone give any advice? Thanks
clark forklifts have a safety device on the brake pedal hydraulics that prevents movement when lifting the forks
check the operation of that safety device as it may be jammed in the neutral position
Error code 218 is displayed on a forklift electric crown sc 4200 once we start it
you should checkout this website www.reliable-store.com that has books on all vehicles, name it they have it.
it covers wiring diagrams, electrical diagrams, fuse diagram, torque specs, PCV, error codes, fault codes, service info, repair info, parts info, owner's/service/repair/parts/maintenance manuals etc everything totally..
I have 1989 car model and I keep servicing and when needed repair it on my own. worth it !!!
HOW TO CLEAR CODE CANBUS ERROR 2 ON CLARK FORKLIFT?
I have clark forklift not starting
error: canbus error 1
Tm 20 clark forklift error code -46 what does it
sounds like the #1 rectifier is shorted or the insulator gasket is shorted through -also the 1A contactor may be welded shut -usually caused by a weak battery or running a discharged battery too long. -Troy from A-Lift Services
2answers
Clark Forklift GPX25 will not shift into reverse. Unit was working fine a month ago. Do not use the forklift that often about once or twice a month. Unit will work in forward, but not reverse. Even when...
I got the same problem and same model, what's going on with Clark forklift, I look for the new transmission all over internet but can't find any. if any body know what wrong please tell us what to do. thanks a lot. TMV
Top Clark Electrical Supplies Experts
Aron
Don A
Don A
Simon Atkinson
Simon Atkinson
Are you a Clark Electrical Supply Expert? Answer questions, earn points and help others
