Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
WHERE ARE THE SAFETY SWITCHES LOCATED ON A 42in CUT MODEL #247.289010? (SEAT)(DECK)(CLUTCH PEDAL) ANY WHERE ELSE? THANKS S.N.L.
CAN'T KEPT MOTOR RUNNING
    Loyalty:
    Visited the website for 30 consecutive days.
  • Craftsman Master
  • 1,669 Answers
There will be one under the seat and if you have to lift a lever to engage the blades there may be one under that
Posted on Dec 31, 2017
5 Suggested Answers
6ya staff
SOURCE:
rwvanlue
Roland W VanLue
  • 486 Answers
SOURCE: Craftsman riding mower Model 917.270824
I do not believe there is a manual available to the public for troubleshooting, however, you have at least 3 switches to tell the mower to stop when blades are engaged or clutch pedal released.
Seat switch
pedal switch
mower engage switch
The pedal and mower lever switches are identical, and have two sides, one for starting, one for blades turning. One side can fail. The pedal switch is on the frame very close to the pivot point of the pedal/shaft. The mower switch will be under the dash close to the bottom of the lever.
1) Locate and inspect the switches for broken or pinch wires, switch housing, or loose mounting, and how each lever or pedal engages the swtich.
2) This is a picture of the wiring so that you can get a better idea of location.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=917270824&productCategoryId=1509200&brandId=0247&modelName=TRACTOR&diagramPageId=00011&componentDescription=SCHEMATIC%20DIAGRAM-TRACTOR&documentId=P0811014&blt=06
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=917270824&productCategoryId=1509200&brandId=0247&modelName=TRACTOR&diagramPageId=00001&componentDescription=ELECTRICAL&documentId=P0811014&blt=06
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 11, 2009
whatproblem
  • 146 Answers
SOURCE: I have a 20 hp 42 in cutting deck mower. When I
The safety switch is under the seat. It senses weight in the seat, and if it's not working properly, the engine will die when you let out the clutch. It's not always a bad switch - it could have simple come loose or the mounting may be broken or misadjusted. Or the connector to it could be loose, or the wire could have been pinched and broken, so check it all out before you replace the switch.
Posted on Aug 07, 2010
rycgl
Roy Cagle
  • 1545 Answers
SOURCE: I have a sears craftsman riding lawnmower LT2000
There are other safety switches as well. The electrical diagram shows (2) of the interlock switches (part no. 16 in diagram) in the electrical system. The location of the 2nd one could be on the transmission or the clutch/brake pedal. It could also be on the PTO system (blade actuator if you will). See if you can find the other switch on your unit. I have an LT1000 and have NOT looked for them. Here is an electrical diagram on your unit.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Riding-mower-tractor-Parts/Model-917273751/0247/1509200/P0403265/00001?blt=06&prst=&shdMod=
Posted on Aug 14, 2011
Drew Hendry
SOURCE: turn key to run and nothing happens pops fuse
try changing your starter solenoid my craftsman did the same thing and that fixed it
Posted on Apr 22, 2012
Ign switch cut out.need wiring dighram model cv15s ser. 2534924594
that is the motor number,we need the tractor numbers under the seat,if a belt went bad,then the problem is a safety switch,take the top of the engine off and unhook the little black wire from the coil and try to start it,if it starts,its a safety switch,seat,clutch,deck
May 13, 2015 | Garden
WHEN I LET OFF THE CLUTCH THE MOTOR CUTS OFF
You have a bad safety interlock switch someplace. If you're not on the seat and you let off the clutch, it will die, so it's possible the seat safety switch, or operator presence control as it's commonly referred to, has worn out and needs replacement.
Jul 22, 2012 | Craftsman 20 hp 42 in. Deck Yard Tractor
Need to locate the safety switch on a craftsman dlt 2000 lawn mower
witch switch do you need the one near the brake/clutch pedal the one on the seat the one on the the one on the trans for mower deck reverse cut out?
Jul 13, 2012 | Craftsman Garden
I have a sears craftsman riding lawnmower LT2000 model #917.273751 18hp intek engine 42in deck.Engine runs fine but when I release the clutch-brake pedal engine stalls.seems like an intermitent problem...
Aug 13, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
20 hp 42" deck will not turn over. Will start if I
there is 2 to 3 safety switches on there and any one of them will stop it from running. there is one in the seat, one on the engagement of the mower deck and one in the clutch pedal. some models also had an in-line fuse.
Jul 14, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have a 20 hp 42 in cutting deck mower. When I let out on the clutch, the engine shuts off. I am sure it is a safety switch, but I cant locate it.
Aug 07, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a 42in cut 19.5hp automatic trans craftsman when i press the clutch/brake to start then release to drive it cuts off also if i try to engage the blades it cuts off but if i lock the clutch/brake it...
The problem is in the seat safety switch or associated wiring. Lift the seat, find the switch, and take a look for a connector that is off, a broken wire, or a loose or broken mounting for the switch. If all that seems ok, remove the switch and put tape across the plunger so it is activated. Run the mower and see if the problem is solved. If not, replace the switch - it's not expensive. Parts are available from Sears online or at their stores. You'll need the model number of your tractor. Good luck! Please rate my solution if helpful.
Aug 01, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Where are the safety switches located?
one on the cutting deck or engagment lever, one on the clutch. some have one in the transaxle as well. start in neutral only.the deck sensor tell the mower if the blade is in or out of gear,the one on the clutch is for starting.
Jul 19, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Craftsman model # 917.273064 won't stay running when clutch is re
You only have three saftey switches on your mower one on clutch pedal,one on deck engage,one on seat,be sure all are working you can check them by crossing the switches one by one .
May 08, 2009 | Garden
Tractor starts fine but wheni take my footh off the clutch the tractor dies
Most of the time its the seat safety switch .
Alway engage and disengage mower deck too as there is a safety switch there too, some times its just needs moved some, its not the clutch pedal safety switch.
Feb 28, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
252 people viewed this question
Top Craftsman Garden Experts
john h
Sheldon Dedek
rjivaro
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
