The front deck wheels are touching groung but not the rear ones,my son tried to adjust it but he had the deck wheels on the groung,I have an idea it is wrong because the height is not really adjustable while I'm mowing
SOURCE: Carpet Height Adjusment
In addition to the tab that contacts the bottom of the slider, there are 2 protusions on the adjustable wheel plate that move through holes in the housing, but only when the handle is tilted to begin vacuuming. The wheel plate has a spring that forces the tab against the slider. As the handle is moved to the upright position, the protusions move back through the holes, taking the tab away from the slider and the wheel plate locks in its highest position. Therefore, the position of the slider has no effect while the handle is upright and locked. Hope this helps.
SOURCE: height adjustment not adjusting
The height adjustment wont engage unless the handle is in the down position. Not knowing this led me to overturn the hight adjustment knob.
Step on the handle release, pull the handle back and lay the vac on its side. Then you can get the knob and the plate back together again.
BTW, the reason I had this problem is because the front brush slows dramatically when using on carpet, I thought it was set too low, and turned the knob (in a manly fashion, putting it past its limit). Still working on that one. After inspecting the belt, looks like one worn and cracked spot gumming up the works.
SOURCE: Blades won't disengage
When the mower is off and the clutch is disengaged you should not be able to physically turn the blade(s) if you can then you need to adjust the blade brake (look on the mower deck and you should see what appears to be a brake pad). Your owners manual will show you how to adjust. If you need a copy of the owners manual then I would suggest going to www.managemyhome.com and downloading a free copy of the manual for your mower (Need model number which starts is located under the seat).
SOURCE: getting the height adjustment to work
is this a piece of **** dirt devil? if so, even when you get it back together the design is so flawed that it will keep breaking the belts, I've already gone through 3 in a week! see my other suggestions to remedy this.
SOURCE: Can't adjust the height of the Fluidmaster
You all most have to adjust the height before its installed,then you just hold the bottom and turn the top.
