Black & Decker D2030 Iron Logo
Abdul Choudhry Posted on Sep 02, 2016
It is new d2030 iron. but do not heat up everything works like lights and water spray etc
4 Related Answers
Anonymous
  • 304 Answers
  • Posted on Jul 24, 2008
SOURCE: We have a fairly new
Make a solution of half water and half white vinegar. Fill up your iron and get it good and hot then let it sit a couple hours. flush out and repeat as necessary. Hope you find this helpful. Please give me a fixya rating If this works for you. It works very well as long as it is not completely filled with scale. Once you have it
good and clean By a gallon of bottled water at the market and use that for your Iron and you will never have a scale problem again. I learned how to do this 20 years ago from a 80 year old woman from england. If it is really bad you can up
the vinegar concentration but do not go higher than 2 cup to 1.
George
electrodynam
Gordon Meredith
  • 35 Answers
  • Posted on Mar 16, 2009
SOURCE: the black and decker iron wont heat up
It probably has a high temp overload opened up inside or the thermostat control has gone bad.You can only tell for sure by taking the unit apart and testing the circuit for continuity.The steam feature on the iron is heated by the same element that heats the iron so it wont work.the element itself could also be bad,but I have never seen one go bad.You will have to check each component seperately to find the damaged part.or you can test the whole circuit at the plugs end,and use a jumper across each part until you have continuity through the unit.Make sure the thermostat is turned all the way up.the part that you are bypassing when you get continuity is the bad part.
You can buy a cheap continuity checker at any lowes,or even wallmart for that matter.
Anonymous
  • 43501 Answers
  • Posted on Jul 14, 2010
SOURCE: D2030, Digital Iron - display lights up, but the
Here is a tip that will help you to troubleshoot our iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Anonymous
  • Posted on Mar 06, 2011
SOURCE: D2030 Iron: Iron keeps shutting off...like auto-shut off is al...
OK... quick disclaimer. Me = not responsible if you break your iron, set something on fire or electrocute yourself. If you're not sure what you're doing, find a qualified person to help or trash the iron. Getting hurt isn't worh a $40 iron.
That said, mine had the same issue... in my case, was a break in the cord.
Before you do anything that follows, don't forget to drain the iron. You'll have a big mess if you don't. :)
Accessing the cord connections requires a security screwdriver. You can buy one at a hardware or electronics repair store. OR if you're chep like me, make one yourself by using a Dremel with a cutoff wheel to cut a notch in a thinner blade, flat blade screwdriver. Any cheap flatblade screwdriver will do (eye protection recommended since you'll be grinding metal).
Unscrew the two screws in the back. Once removed, the colored plastic cover can be removed by inserting a screwdriver near the tabs that hold the cover in place and prying a bit.
Removing the inner cover is a little trickier.
The handle under the power indicator light (the red one) has an upper and lower section. Squeeze the lower portion of the handle directly beneath the light pretty firmly. You'll notice a slight separation between the back section and the handle. The back section is what you'll remove. I removed mine by squeezing the handle and pulling the power cord straight backward (I know that sounds odd, but it was the easiest way to get some leverage, plus it's already broken, remember???) Don't pull super hard, but firmly enough to separate the back panel from the back of the iron.
Once the back cover is removed, it's a pretty simple cord change. As there are a few more wires than some people are accustomed to, I recommend writing down the wire combos so you can reattach everything as it was.
If you have difficulty removing the crimped wire nuts (the plastic covers), you can use a pair of pliers to squeeze opposite the crimp and they'll open up enough to allow the wires to slide out.
From there, reassemble... opposite of the disassembly order.
Mine worked perfectly after this quick fix. Hope yours does too. Good luck and be safe!
My Black & Decker D2030 Iron fell on the floor and it is leaking water from the tank - can it be repaired?
if the crack is visible and isn't on a part that gets heated then super glue will work 4 you , plus if you cant access the crack a separate 99 cent squirt bottle kept handy will still allow you to use the iron ,just squirt and swipe the iron across the surface ,steam will be made if irons hot enough
Jun 03, 2016 • Irons
MY BLACK & DECKER D2030 DOES NOT POWER ON?
my black nd decker iron lights up but will not heat.
Iron not heating
Here is a tip that I wrote about Electric Irons and why they do not heat....
Electric Iron not Heating Up or not Working Rightheatman101
1helpful
6helpful
Stopped heating
I work for Black & Decker. Any part that someone is telling you to purchase for that iron isn't from Black & Decker. Their irons are no designed to be repaired. If the iron is no longer heating, it needs to be replaced. Please call our customer service department at 800-231-9786 so that we may determine your warranty status.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
F2000 iron won't heat up
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
heatman101
My Black and Decker D2030 shoots water out
You need to be using distilled water, so that minerals will not build up on or in the soleplate. It sounds like the mechanism to control the flow of water (not sure what it is with that particular iron) to the soleplate, but while the iron is cold, hold it over a sink or something where water will not cause a problem and change the setting from steam to dry several times, then shake the iron to release trash. It should work then.
New iron, stopped heating and leaked water
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
We have a fairly new B&D iron Cat # D2030 1. How does the "cleaning' work. The iron started to leak during ironing and it indicates "Cleaning". Do we need to do anything?. An excellent...
George
Top Black & Decker Irons Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
