Carolyn, REMOVE BATTERY FROM HP LAPTOP, Check the attached links,instruction and guides, you can Google search your (make and model# battery removal) if links do not show your particular battery replacement.
Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Removing and Replacing the Battery for HP Pavilion dv7 7000 dv7 7100 and...
You don't say which model, but usually there are two battery latches on a laptop. Turn it over on its back and look for two plastic sliders -- usually with little padlock symbols imprinted beside them. Move both to the unlock position and slide the battery (or the battery compartment cover) off of the laptop body.
Reset the password on any HP laptop.
Reset the BIOS password on an HP laptop computer when it has been forgotten or when preparing the laptop for sale to a new owner. Learn how to erase an unknown BIOS password by physically disconnecting the internal batteries. Avoid spending hundreds of dollars at a service center to make changes that can often be performed at home by anyone with the ability to take an HP laptop apart and put it back together again.
Power down the computer if necessary by holding the power button down for six seconds until the power shuts off.
Step 2
Disconnect the power cord from the HP laptop computer. Remove the battery by flipping the computer over onto its cover and releasing the battery clips as indicated by the illustrations on the bottom of the laptop or in the owner's manual. Lift the edge of the battery nearest the clips up first, then pull the battery out of the laptop.
Step 3
Remove the screws that hold the hard drive cover in place and remove the cover. Take the hard drive out of the laptop by removing the two retaining screws and pulling the drive gently away from the connector, then lifting the hard drive bracket or tray out of the computer.
Step 4
Remove the screws that hold the memory compartment cover in place, then remove the cover. Remove the memory modules from the sockets by spreading the metal retaining clips gently apart and allowing the module to spring upward. Pull the memory straight out of the socket at the angle it rests at when sprung from the retaining clips.
Step 5
Remove the Real Time Clock (RTC) coin cell battery from the memory compartment by pressing the retaining clip and pulling the coin cell battery out of the socket.
Step 6
Allow the computer to sit without the battery for an hour, then reinstall the memory and hard drive, but leave the coin cell battery and the main battery out of the system. Connect the AC power adapter to the system and power it on to clear the BIOS password.
Step 7
Power the system back down and remove the power cord to reinstall the coin cell battery and main battery.
hope this helps
John
