Is it an icemaker? Either the water valve is bad or the freezer isn't cold enough or the ice maker is bad. Is it just a ice cube tray? Then it's not cold enough.
Set freezer temp to lowest number, use "ice plus" feature. (it goes back to non-ice plus after about a day on it's own though) Dump excess ice into freezer storage bin if it gets full to keep it making more ice if needed.
I took the arm of the ice-making machine out of the slot and put it back in, pushing it snugly inside the slot, then raised and lowered it several times. Then, with the arm in the up (stop making ice) position, I felt inside the ice-making tray, where I noted there were ice cubes as well as a sheet of ice at the base of the ice-making tray. I poured approximately 24 oz. of hot tap water into the tray to melt the sheet of ice. I turned the freezer temp control to "warmer". I think the freezer temp setting was too cold, causing the ice maker to freeze the water before it could make cubes. I have a working ice maker again!
Cynthia
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow. You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
In my Kitchen Aid bottom freezer there is a metal arm(?) that I lift up to stop the ice maker from making ice. When I start running low on ice, I push the metal arm(?) back down for it to make ice again. Hope this is the solution for your Kitchen Aid too.
Hi: As we don't (as in I) know the actual temp. in the freezer, this is a simple and free try. Cold is cold. The temp in the freezer has to be 0 degrees to make ice. They are thermally protected. A good guess for temp. is your ice cream. Is it rock hard? A lot of refrigerator thermometers are inaccurate. Just try setting your freezer colder. Ignore human nature and don't check the freezer every 30 Min's. You will never get to 0 degrees. I hope this helps, Jeff
The more "frozen items" in the freezer, the less of an impact the introduction of a non-frozen item (water in ice maker) will have. Hence a freezer full of frozen item will freeze water faster than a empty freezer but the difference would be negligible.
If the Temperature in the Freezer is not cold enough, the Ice maker will not make ice. Make sure the freezer is below 10 degrees or so. Zero is where you want it for the best ice production. What was the reason for defrosting in the first place? Should be frost free?
