Door doesnt go into lock mode and machine doesnt start cyclying
Michael, the door lock/latch mechanism should be tested, if faulty replace. Have a good repair Tech. check, diagnose and estimate repair. Make sure to at least look at the first link, it tells of a reset procedure that may fix your washers door latch problem. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://baubilt.com/?p=1318
How to replace washing machine door lock on Balay Bosch Neff and Siemens
http://www.repairclinic.com/Shop-For-Parts/a11b129/Bosch-Washing-Machine-Parts
A code E27 means a problem with the door lock. Try
unpluging the machine for an hour and see if it resets the lock.
If not remove the cover on the lower right
corner you will see a white plastic pull cord. Pull the cord and pull open the
door. If that doesn't reset the door lock you will need to replace the lock.
