SOURCE: My machine makes pin size
It's a nasty twisty thing, my dear. It happens in just about every machine. The only thing you can do to be absolutely sure is to put those thin t-shirts in a pillow case, Strap it closed with one of those "what's those hand-cuffy things called" things? and pray you don't get small pin-sized holes in your pillow case.
SOURCE: Fisher & Paykel Washing Machine
Close your external inlet valve to the machine. Disconnect hose of washing machine from the valve; keep a bucket there and open the valve to see if water comes well. Next check the screens (filters) on the hose, clean well. This shd be done on both ends of the hose/s. Refit carefully. Check for leaks. If water still (don't forget to open the valve!) does not enter machine change the inlet valve of your wash machine. Can be done yourself. Rate me pl...........if helped.
SOURCE: KNOT UP
depends on how full your machine is.
There is no solution for except try to wash full loeads which decreases the chance of notting
SOURCE: My pant legs get very twisted in the washer
these machines are sensitive to loads. try only doing the jeans seperatly.
SOURCE: holes in clothes
Inspect the rubber seal, and steel drum to make sure there is no foreign object sticking out, which could be tearing holes in your clothes. Also check to see if any of the holes in the steel drum are dented in. or out or misshaped, as this could cause the tumbling action of the drum to tear clothes.
