SOURCE: i would like to download a repair manual
You might want to try this location:
http://files-netexpress.com
You will have to sign up and register but they do have the manual posted
SOURCE: i need a parts diagram for a 743 bobcat steer skid
i have a 743 bobcat the hydraulics are noisy and moves very irratic now like its not getting any fluid any ideas
SOURCE: How do you bleed the hydraulics on a Bobcat 751 skid steer loader?
Hi Joseph:
Usually hydraulic components will "self clear" any air in the system just by trying to cycle through the functions a few times.
Have to ask the question............
Did you remove and replace the hoses one at a time, or did you take them all off at the same time?
The reason I ask is............ Could there be a remote possibility that any of the hose onnection locations were switched?
Testimonial: "I did remove three of the hoses at one time simply two of the hoses were rubbed through and to remove one of the ones I had to remove another to get at one rubbed through. However I am 100% sure they are installed correctly because only two of the hoses are the same diameter and they run parallel to each other and one has to be installed before you can install the other. Thank you for your help. I see I need to get more hydraulic fluid as my level went down after trying system. Joe"
SOURCE: Bobcat T190 shows code 47-21. Anyone know what this is and how I can fix it. Thanks. Daryl.
Hi daryl, The link below is error codes for a loader....
47-21 8 Volt Sensor Supply Out Of Range High
http://cdn-4.psndealer.com/e2/dealersite/images/bigvalleytractor/AllServiceCodes.pdf
