Computers & Internet Logo
m
milton gregory Posted on Jul 30, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I bought a cisco valet router used and do not know the password , how do I change the password
Cisco valet wireless router
Eric
Level 2:
Scholar:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 162 Answers
  • Posted on Aug 02, 2016
 Eric
Expert
Level 2:
Scholar:
Cheetah:
Answers
162
Questions
0
Helped
40399
Points
319
On the back of the router is a reset button. Press that in for 5-10 seconds. It will reset to factory specs. Once you reset the Valet Hotspot, all of its customized settings (network name, wireless security, etc.) will be erased and the hotspot's IP address will be reverted back to 192.168.1.1, with a default password of admin and no username.
What does it mean to "console into the router."
Log in to the router. Open a browser and type in your Ip address to the router and the login password. (They should be on the label on bottom of router. )(NOT THE WIFI PASSWORD) once inside you can change the WiFi password.
tip
Guide to Reset Password on a Cisco Router
How do I reset the password on my Cisco router?<br />I bought a Cisco 1700 router from an auction, but there is a password. How can I reset the router to original factory specifications? <br /><br />Sky sagem wireless router reset password? I just got this sky wireless router second hand and it has a password set on it. i tried to press the reset button at the back but it does not do any thing, it still comes as a password is set.<br /><br />How to reset password on dlink wireless router? I have a dlink wireless router model number DIR 825 . It works good but I am trying to access internet on my ipod and the password i have set is incorrect , this also happened when i tried to access internet on my laptop. When i first set up my ps3 i dont recall having to put a password in but this was when i first got the router. How do i reset the router password or find out what the password is AND if i reset the password or reset my router will my ps3 have to be reconnected or will it stay?<br /><br />How to reset password on a router? I recently acquired a linksys router (used) and need to know how to reset the password so that I can use it. Also, is there any way to modify a router to be useful as a cell/wifi blocker, or as a signal booster?<br />... <br /> ----From Yahoo Answers<br /><br /><br />To reset password on a Cisco/D-link/Linksys/Netgear router is a very common problem among people who want a secure network environment for surfing on the internet. If you are confused with the complicated procedure to reset or change the password on a router, or if you are trying to configure a Cisco router, but a password is blocking you from enable mode, don't worry, just do the steps as follows, password reset on a router is no longer upset to everyone.<br /><br />First, be informed that what you need:<br />.<a href="http://www.router-switch.com/Price-cisco-routers_c1">Cisco Router</a><br />.Computer<br />.Internet Connection<br />.Blue Serial Cable<br /><br />Guide for You to Reset Password on a Cisco Router:<br />1. Download a program called Putty from the first resource site below. PuTTy is a terminal emulator application which can act as a client for the SSH, Telnet, rlogin, and raw TCP computing protocols (PuTTy on Wikipedia).http://en.wikipedia.org/wiki/PuTTY<br /><br />2. Connect one end of the blue serial cable to the Cisco Router and the other to your computer. Open up the Putty program on your computer and select the radio button next to "serial" on the right-hand side of the start window. Click on the "Open" button in the bottom right-hand corner of the Putty start window to open the terminal.<br /><br />3. Power the Cisco Router on. As soon as the router begins loading in the green and black Putty terminal window, press the "Ctrl" and "Break" keys simultaneously until its going into rommon mode.<br /><br /><br />4. Once in rommon mode, you have to change the configuration register number to make the router boot from a blank configuration file. For the 2800 series Cisco Routers, the command "confreq 0x2142", changing the register number to 2142, worked. Search on cisco.com for information on your particular <a href="http://www.router-switch.com/Price-cisco-routers_c1">Cisco Router Series</a>.<br /><br />5. Type the restart command in rommon mode, which is "reset". This will boot the router up again. When it is finished, you should be able to type "en" to get into enable mode without a password.<br /><br />6. Once you change the running-config in RAM and save it to the startup-config in NVRAM, remember to change the configuration register number back to its default (usually 0x2102). This is important if you change anything on the running-config. <br /><br />Easy five steps help you finish resetting password on a Cisco router. Easy instruction, easy to follow. <br /><br />
on Jul 19, 2011 • Computers & Internet
Verizon dsl and cisco valet
Connect your computer directly to the Internet modem and make sure that you have Internet access directly from the modem.
If that is working properly then connect the modem to the Internet port on the router. Connect the computer to port 1 on the router.
Reset the router and configure it manually.
Here is link which will help you troubleshoot Cisco Valet M10 or M20 router
How to change password on cisco m10 router
Press and hold the reset button of your router and use the WEP or WPA located at the bottom of the device.
My son reset m20 valet plus now we can not use internet on devises.
log in to the router and reconfigure the router.
type in 192.168.1.1 on the address bar, or what ever the router ip is, then log in using the default login user/password as admin
I need my security code for my cisco valet wireless router plz help
Welcome to Fixya. If you need you Security Key or Password (Network Key) on your router you need to access the Wireless Settings Page. To access the router page you need a working computer that is connected to the router. To access the router page just open a browser then type 192.168.1.1, the Default username is admin and the password is admin. Go to the Wireless Settings and you'll find the Network Key or Passphrase (Security Code). You can alsoThen Personalize you Network Key or Passphrase so that you can easily remember it.
Thanks for using Fixya.
Top Cisco Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
