Cannot login on the printer of the web interface. None of the default passwords work. How can I do a hard reset and reset the passwords back to the factory default settings and passwords. I can get into the service mode to reset any settings if needed, I just don't know what to change to reset the machine for the default password(s). I erased the memory in the settings accidentally, and have not been able to login since.
SOURCE: xerox phaser 3200MFP lost password
To my knowledge that will reset the password to the default.
SOURCE: Printer Password
If you reset the network card on the 8008 back to factory defaults it will reset the web password back to 'sysadm'
To reset factory defaults power the pritner on holding down CLEAR, keep CLEAR held down whilst you power the printer ON, keep the clear button held down untill you see RESETT on the display.
Resetting factory defaults will reset all network settings EXCEPT - IP, Sub net and Gateway address
SOURCE: Aficio 1035 web interface user name and password
The Default factory passwords are not what you have listed. They are the following:
User name: administrator
Password: password (or possibly leave blank)
Give that a try.
However, the web interface isn't all that special on this older model anyway. All you need to program are the Ip address, and subnet mask, as there is no scan to email function, and the scanning can only be done via a software, that you won't have, and is getting difficult to find, because it is no longer supported, and just as complicated to configure should you find it ("Scanrouter V2 Lite" is the name ) as opposed to direct scan to folder. By the way this scanning software is NOT Vista compatible should you find it.
If you can't log into the web interface....on the machine, go to "user tools', "system settings", Interface settings", and set your IP address and subnet mask...that's it.
Please rate response :)
