SOURCE: mower quits when engaging mower deck of husqvarna yth 2348
Try putting a jumper wire on the wire going from the engine to the seat. Take that plug and put a wire from one side to the other. Be careful not to cut your feet off when engaging deck.
SOURCE: release brake engine dies engage blades engine dies
there is a saftey switch on the deck that has shorted out need to replace
SOURCE: Bobcat ZTR new blade brake won't engage while engine is running
SOUDS LIKE THE CLUCH SAFTEY SWICH IS BAD OR THE SEAT SWICH MAY BE BAD CK THAT OUT AND LET ME KNOW OK THANKS
SOURCE: the mower shuts down as soon as I engage the
Same thing happened with me, but in this case, the blade shaft was bent and the mower automatically disengaged.
SOURCE: I started the mower but the blades will not turn.
Most all riders have a safety seat switch now and they do malfuction alot. They are under the seat and are ez to replace most of the time. First look for a wire that is grounding due to rubbing a sharp object. That can be fixed with black tape
Good luck!!!
