It doesnt affect the performance or driveability of vehicle -its your blind spot assist system didnt specify vehicle if under warranty bring to dealer for repairs or if vehicle was in an accident recently renotify insurance company following link can assist you further FORD BLIND SPOT SYSTEM MALFUNCTION REPAIRLincoln Electric MKZ Owner Manual Page 229
It is the winter. What you see as water is just condensation from the water that is in the fuel at molecular level. The test is, Are you losing water from the coolant system?
Water is nowhere new the valve stems, just oil.
Leave everything as it is. Re-evaluate in summer. The head gasket can be tested with a coolant system pressure test.
The problem is more likely in the bcm. Check to see if any rainwater is leaking on the bcm, but the dash lights going out is not consistent with bcm failure. Look for possible wiring issues under the dash--maybe you have rat damage.
If a SRS fault exists, the RCM sends a message to instrument cluster module to flash a coded sequence which is called a lamp flash code (LFC) on the air bag warning indicator. Each LFC is flashed 3 times after which the air bag indictor will remain lit for the remainder of the key-on cycle. In addition to the self-test at start up, the RCM continuously monitors all of its external and internal circuitry for faults.
While the LFCs are an indication of a general concern in the supplemental restraint system (SRS), the DTCs are more specific. The DTCs can be retrieved from the RCM with a scan tool via the DLC.
DTC a c
LFC b
Description
Action To Take
Continuous Lamp
The Air Bag Warning Indicator is Illuminated Continuously (RCM Disconnected or Inoperative, Loss of Battery Feed or Loss of Signal Ground)
Go To Pinpoint Test A .
B1048 c
Passenger Side Air Bag Cross Link to Another Firing Loop
Go To Pinpoint Test B .
B1049 c
Passenger Seatbelt Pretensioner Cross Link to Another Firing Loop
Go To Pinpoint Test C .
B1054 c
Driver Seatbelt Pretensioner Cross Link to Another Firing Loop
Go To Pinpoint Test D .
B1057 c
Driver Air Bag Cross Link to Another Firing Loop
Go To Pinpoint Test E .
B1231
13
RCM Crash Data Memory Full
INSTALL a new RCM and CARRY OUT programmable module installation (PMI). REFER to Restraints Control Module (RCM) and Inspection and Repair After a Supplemental Restraint System (SRS) Deployment in this section.
B1317
Continuous Lamp
Battery Voltage High
REFER to Section 414-00 .
B1318
Continuous Lamp
Battery Voltage Low
B1342
24
RCM is Faulted
INSTALL a new RCM and CARRY OUT programmable module installation (PMI). REFER to Restraints Control Module (RCM) in this section.
B1871
25
Passenger Air Bag Deactivate Module Fault
Go To Pinpoint Test F .
B1884
27
Passenger Air Bag Deactivation (PAD) Warning Lamp Circuit Failure
Go To Pinpoint Test G .
B1890
27
Passenger Air Bag Deactivation (PAD) Warning Lamp Short to Battery
Go To Pinpoint Test H .
B2292
33
Restraint System - Seat Belt Pretensioner Fault (Driver Pretensioner Circuit Fault)
Go To Pinpoint Test I .
B2292
34
Restraint System - Seat Belt Pretensioner Fault (Passenger Pretensioner Circuit Fault)
B2293
19
Restraint System - Air Bag Fault (Driver Front Air Bag Circuit Fault)
Go To Pinpoint Test J .
B2293
21
Restraint System - Air Bag Fault (Passenger Front Air Bag Circuit Fault)
B2296
42
Restraint System - Impact Sensor Fault
Go To Pinpoint Test K .
B2434
53
Driver Seat Belt Buckle Switch Circuit Short to Ground
Go To Pinpoint Test L .
B2435
53
Driver Seat Belt Buckle Switch Resistance out of Range
Go To Pinpoint Test M .
B2477
54
Module Configuration Failure
This DTC indicates programmable module installation (PMI) has not been done to a newly installed module. CARRY OUT PMI. REFER to Section 418-01 . CLEAR the DTC. CARRY OUT the self-test.
B2607
57
Harness/Configuration Mismatch
This DTC indicates the RCM is configured incorrectly. CARRY OUT programmable module installation (PMI). REFER to Section 418-01 . CLEAR the DTC. CARRY OUT the self-test. If DTC is retrieved a second time, INSTALL a new RCM and CARRY OUT PMI. REFER to Restraints Control Module (RCM) in this section.
B2691
53
Seat Belt Buckle Switch Circuit Fault, Front Driver's Side
Go To Pinpoint Test N .
C1414
29
Incorrect Module Design Level
VERIFY RCM part number is correct for vehicle.
U0100
14
Lost Communication With ECM/PCM
REFER to Section 418-00 to diagnose the communication concern.
U2023
14
Fault Received From External Node
U2050
14
No Application Present
This DTC indicates programmable module installation (PMI) has failed. CARRY OUT PMI. REFER to Section 418-01 . CLEAR the DTC. CARRY OUT the self-test. If DTC is retrieved a second time, INSTALL a new RCM and CARRY OUT PMI. REFER to Restraints Control Module (RCM) in this section.
a DTC: Diagnostic trouble code, retrieved using scan tool.
c Cross-link DTCs will be retrieved in pairs to identify the cross-linked components.
b LFC: Lamp fault code, flashed on air bag warning indicator.
It could be the speaker that alerts you when you back up. If it is going bad, you will get a cross traffic system fault. A replacement speaker will cost you $20 or less and a half an hour of your time if you are handy. (It is possible the fault could be caused by something else, but my speaker was making a screeching sound for several weeks, then stopped working altogether. After reading several forums and blogs, I felt confident the speaker was my issue.)
I have a 2010 Milan with the Sony speakers. I read about taking out the seat to access the speaker, but did not want to do that. found several sites that said one could go in from the top, so that's what I did. The speaker is on the driver's side.
The speaker grill is made of plastic and has tabs down the sides. I used a long, thin flat screwdriver to pop it out. You may not get it back on perfectly when you are done. If that's important to you, then you may want to remove the seat instead. You can also use double-sided tape to hold it in.
After removing the grill, I removed the stereo speaker. I used a 7mm socket wrench. The backup speaker is to the right (toward the outside of the car) under the deck. I went into the trunk and pushed out the push pins to remove the speaker. See this site for good pictures: https://imgur.com/gallery/NCr3w
After removing the speaker from its moorings, remove the connector by using a small flat screwdriver to push on the part of the connector showing through where it connects to the speaker.
The replacement speaker came with tape. I found that easier than using the push pins again. I would use double-sided tape if it did not come with it.
The stereo speaker went back in rather easily, then the grill, which is not perfect, but again, I did not have to remove any seats.
have a pressure test done on the box to check for internal faults. Any high pressure leaks will cause heat. check the filter and while the pan is off adjust the bands and clutch packs . Check the radiator cores are not blocked as engine temperature will affect the transmission oil temperature . check oil level as extra oil will cause frothing and over heating.
The positive cable will have a cross symbol on it,,,the negative will have a dash symbol... warning,,,do not get them mixed up,,,remember,,,positive to positive,,,negative to negative,,,if you cross the cables and get sparks,,,one or both of the cars (if your getting a jump from another car) will suffer great damage to the charging system.
