Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
Testimonial: "THANKS"
SOURCE: Tivo Remote
I found this usefull tip on the Tivo website. Here is the link for the page. I hope it works for you. http://customersupport.tivo.com/LaunchContent.aspx?cid=a8722f21-6f9a-42ec-8626-02dcef837619&anchor=undefined
SOURCE: ILO-26HD
We had bought the extended warranty, so we took it back and got a new TV of a different brand. We had to pay the difference, but it was worth it. The warranty even carried over to the new TV.
SOURCE: remote problem
I understand Ilo's are made by Tatung. You may try 0055 or 0003. I haven't confirmed this, but it's worth a try. http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
SOURCE: ILO-26HD remote problems
my remote does not work with ilo hdtv26 it turns power on and off. channel is stuck on one channel. buttons on side of tv do not work at all. any suggestions from you wizards!
SOURCE: ilo tv/universal remote codes
Here are some to try, mine was 0189, but there are many to try. 0051 0189 0053 0198 1070 1024 1023. I think some listed codes for Emerson work as well.
It took me all afternoon to finally get the right code, but for the ILO 26HD with the SHAW Direct Dish Remote ARRIS IRC600. THE 5 digit code 10765 WORKED. ALL of the functions work. I want to share this to save someone else the AGGRO!
THANK YOU!
