MB-1001B. Base is black not silver. Purchased at Target.
SOURCE: My Magic Bullet has broken. I need to know how to get it fix.
This happened to me, and I was told by the company that I had to purchase a brand new base, that the plastic turning device can not be repaired. If it is under warranty, you may not have to pay anything but shipping, and maybe not that either. If you do not have the number to the company, go on-line and and search for it. Call the company and report what the problem is.
SOURCE: magic bullet base is full of particles
Yes its easy to take the Magic Bullet apart.
1. First pry out the 4 black rubber feet on the base with small screwdriver and unscrew the 4 cross head screws revealed below.
2. Remove this black base to reveal the inner black base Unscrew the cable clamp - 2 screws and the 3 screws that retain the remaining black base to the body of the bullet - slide it off over the power cable.
3. Turn the bullet the proper way up and pry out the 3 white rubber bumpers with a screw driver blade that are set inside for the cup to rest on - each is located with two rubber pins. Once all 3 are removed you will reveal 3 more cross head screws - these countersunk - remove all 3 and then the internal motor will be free to lift out through the top of the Bullet casing.
4. Its possible to slip out the 3 white plastic sliders - taking care to note how they seat each on a small spring to cleanup both the slides and the sliders.
To re assemble step by step in reverse - noting to align the motor cable with the cutouts on the bullet base.
SOURCE: where to buy a magic bullet base gear?
Hi Pamela... Magic bullet base gears can be purchased from amazon (my recommendation). Enter this link Healthy Blend of Power Precision and Value and choose carefully which one fits (by shape, size, price etc). I hope this was helpful. enjoy
SOURCE: Magic Bullet Blender Repair
Take a look on amazon here Amazon com magic bullet blender parts. I hope it was helpful. enjoy
