We recently added 3005AC to the network but it has the same IP address as our old 3040C. We want both 3040C and 3005AC to be on the network. In order to do so we need the IP address to 3040C changed, otherwise if we connect the 3040C to the network while the 3005AC is connected, it'll wipe out the 3005AC and default to the 3040C. So how do i change the IP address to the 3040C?
SOURCE: how do I create/set up the IP address for a
On control panel press "user functions" , then select admin tab, press password and type password (default is 123456),press network and then ipv4. There you need to type in free IP address, subnet mask and gateway.
For more ask your network admin.
SOURCE: Toshiba estudio 3511 will not allow me into the network config
First of all, the default password for Admin is '123456'. The network button is grayed out because network is initializing. Which means the network portion of you copier is trying to boot up. If it never finishes booting up, you will need an authrized technician to re-load system firmware on your machine.
SOURCE: Linux print to eStudio 232 printer
Did u install the driver?
Driver can be downloaded at below link:
http://www.eid.toshiba.com/support/controllers/ebridge282-283%20series.shtml
SOURCE: we have a toshiba e-studio
try making the ip on the machine the last 3 numbers 250 if there is no ip confict add a new port in the print driver with the new ip if you do not know what the computers ip is go start,run type ic cmd press enter and the in the window type ipconfig /all that will give you the ip config of the computer. if there are not to many computers on the network check all the pcs and pick a ip add that is not used by the pcs and give it to the copier
SOURCE: toshiba studio 350 network printer setup
I can send you the Networking Manual if you send an email to [email protected]. Please put 'Toshiba e350 network' as the subject or you can go to the link that I have included here. http://www.eid.toshiba.com.au/Downloads/manuals/230-280_350-450_3511-4511/eS230_350_3511_NetworkAdminGuide_Ver.00.pdf
