Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Mower will not shut off
Mower will no t shut off
    Dedicated:
    Visited the website for 20 consecutive days.
  • Craftsman Expert
  • 242 Answers
When the key is turned to the off position it grounds out the ignition coil to stop the spark plug from firing and also it interrupts the 12 volt signal to the Carburetor solenoid which will shut off the gas supply to the main jet. For both of these to not happen it would most likely be the key switch as it is the only thing they have in common .
Posted on Jul 16, 2016
Anonymous
SOURCE:
Snapper pro s50 mower as mower heats up blades shut down. Will not come back on till mower cools completely down.
check for a thermo-coupler switch which shuts motor down when overheating to protect it from internal damage. also check oil level.
I’m happy to assist further over the phone at https://www.6ya.com/expert/howard_977676954994c5b2
May 03, 2016 | Snapper Garden
My huskqvarner lawn mower shuts off when you put it in gear or reverse. It starts good but when we try to do anything with it it shuts off
Look under the seat for a switch. This is a safety interlock that shuts off the engine if you fall off. If the switch doesn't activate then the mower thinks you are not in the seat and shuts off the motor.
Apr 03, 2016 | Garden
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Wire seat so mower doesn't shut off
Put a piece of wire hooped in plug the seat switch plugged in to. It not good to jumper out safety items.
May 03, 2012 | Husqvarna Riding Lawn Mower 42 Inch Cut...
I have a rzt 54 cub cadet, when i engage the pto it cuts breifly then the mower shuts down PLEASE HELP
A battery going bad may be your culprit. I found out just the other day that your mower can keep running but when the battery gets too weak, the pto clutch disengages and shuts down,
Apr 29, 2012 | Oregon Scientific Electric PTO Clutch for...
Mower shuts off while mowing grass
Check the switch that is located under your seat. If you are not on the mower while it is running the switch tells the mower to shut off. hope this helps
Jul 12, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Mower quits when engaging mower deck of husqvarna yth 2348
Try putting a jumper wire on the wire going from the engine to the seat. Take that plug and put a wire from one side to the other. Be careful not to cut your feet off when engaging deck.
Mar 30, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Mower starts but instantly shuts off
either water in carb bowl or plugged high speed jet
Sep 18, 2008 | Troy Bilt 5.5hp Self Propelled Mower
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
82 people viewed this question
Top Craftsman Garden Experts
john h
rjivaro
Marvin
Marvin
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
