This code is for flow error , its telling you the washer hasn't detected the proper flow of water in the time allotted for it to fill up , ck your hoses for kinks and your shut off valves for being full open (they need full open) also can be a fault in the flow sensor inside washer (happens a lot with high mineral water ) it sets up hard inside the flow sensor and blocks it from working well
ohh and I have seen in one case the homes water pressure was too low for washer to work as well , but this is rare and that one case was on a well system not a city supply ,but this too is fixable as well (pun intended)
Hi
Error code FH appears when No water is detected entering machine or Pressure switch trip is not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Press PAUSE/CANCEL twice to clear the display. If there is no water entering the unit then make sure that the inlet valves are working fine. You may need to check the continuity at the inlet valves. If the valves are fine then check whether inlet water hose, it may be plugged. Also check for inlet water screen at the valve. However, if the water is entering into the washer then the Drain pump might not be working. Also inspect the Pressure Switch hose whether it is in good condition and properly connected to Tub and Pressure switch. Also check hoses for leak and inspect the flow meter. Hope this helps...
Daniel
Hi
Fh or Fh ?
