Dishwashers Logo
R
Ray Friesen Posted on Jul 14, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Miele G 2170 dishwasher has all program lights flashing and beeps three times repeatedly . This happens after a minute of operation . Must be a code for something . What is the code for ?
andrew petersimes
Level 2:
Sergeant:
  • Expert 248 Answers
  • Posted on Jul 14, 2016
andrew petersimes
Expert
Level 2:
Sergeant:
Answers
248
Questions
0
Helped
91244
Points
921
Http://www.user-manuals.com/user-manual-MIELE-G2170SCVi.html MIELE G2170SCVi Instruction Manual 4 99 MIELE G2170SCVi It complete owner... I think you will locate your blinking code in this link. Thank you and leave feedback.
I have a Miele Advanta G2170 dishwasher. The lights are flashing?
It may have a leak. There is a sensor that halts the cycle if it senses a leak. Call for service.
https://www.google.com/search?q=Miele+Advanta+G2170+beeps+and+lights+flash
Have a Miele G1220SC dishwasher. It recently developed a strange problem: when switching it on ALL program lights come on and the machine starts taking water. after a while it stops taking water and starts...
follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
My miele dishwasher beeps and all yellow lights flash after only 6 minutes
I have a Miele Futura from about 2011. In 2019, I had the issue were all three yellow lights, cleaning, drying, and end, were flashing, initially after a cycle was running and later, after several resets, almost immediately after trying begin a cycle. I strongly suggest watching Scott the Fix It Guy on YouTube. He shows that there are basically 3 different reasons why. 1. A leak that is tripping the leak sensor. Put the dishwasher on buckets and watch for a leak without the drip pan. If no leak, check the motor. He shows how to remove and inspect. If there is something in the impeller it will trip those three flashing lights. I did that and found no blockages and that too didn't fix it. The final source is the heater / pressure switch. So I ordered that from Miele ($75) replaced it and now it runs great!!
Miele Advanta dishwasher beeping
Buzzer
The end of a program and faults can be
announced by a buzzer tone.
The buzzer at the end of a program
sounds five times in intervals with a
brief break in between. The buzzer
sounds up to one hour if the
dishwasher is not turned off.
The buzzer for a fault sounds
continuously. The buzzer sounds for up
to two minutes if the dishwasher is not
turned off or the fault is fixed.
The buzzer is activated by default. It
can be set to off, so it does not sound
at the end of a program. The buzzer for
a fault cannot be set to off.
^ Open the door.
^ Turn the dishwasher off o.
^ Press the program button and at the
same time turn the dishwasher on g.
Hold the program button until the
lower right program indicator comes
on.
If it does not come on, start over.
^ Press the program button briefly four
times.
The "Intake/Drain" indicator flashes 4
times in intervals.
The upper right program indicator
shows if the program end buzzer is
turned on or off.
- Upper right program indicator
flashes: Buzzer is turned on
- Upper right program indicator is off:
Buzzer is turned off
it is not easy to disable the buzzer. you have to hold the buttons down exactly the way it tells you to in the manual. you also have to pay attention to the lights and make sure they are flashing the proper sequences. try it two or three times. you will eventually get the hang of it. not sure where you live, but the miele techs have a computer that allows them to disable the beeper if you are unsuccessful. the proceedure is copied below.
^ To change the setting, press the
"Intake/Drain" indicator lights.
three times.
The setting is saved.
Intake/drain light is flashing
When this happens with my dishwasher it usually means that the drain is clogged with food/debris.  To fix 1) remove bottom dish rack from machine 2) using a small cup, scoop out as much water as possible 3) remove inlet drain cover and unsnap the plastic insert and remove 4) rinse the plastic part and reinstall 5) start machine 6) if light still flashes, repeat steps 3 4 and 5 and restart
3 lights are flashing at end of dishwashing cycle cycle
I shut off the dishwasher, held a few of the buttons together at the same time, let it sit for 5 minutes, then restarted it and it worked!
4helpful
Dishwasher wont complete program 1 2 or 3
Did you ever resolve this problem with your dishwasher, unfortunately i've exactly the same type of problem!
Thanks Steve
Dec 18, 2008 • Dishwashers
2answers
Brand new Miele 2170/2180 dishwasher. First time we try to use it, it stops after a few minutes, the warning beep beeps incessantly, and all of the program lights are flashing. According to the manual,...
it is just possible you have a problem with the drain.
if you plumbed the drain to a spigot on the sink trap, did you make sure the spigot is not blanked? the sink spigot will be blanked if it has not been used before to stop water from the sink coming out.
just a guess but worth checking. also check drain hose not kinked
Top Miele Dishwashers Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
