Question about Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch washer code d06
Checked harness from control module through ntc back to control panel resistance okay heater resistance is also in spec from control module to pressure sensor connection when go through error codes e-20 shows d06 and d12
Anonymous
SOURCE:
Anonymous
  • 27 Answers
SOURCE: Bosch Nexxt Washer Error Code E02
Check that water inlet tap is open and hose is not kinked....the error is for water inlet taking too long.... Oshie
Posted on Jun 26, 2007
Anonymous
SOURCE: bosch washer error code e3
Error "E3" on a Bosch front loader means there is a problem with the door. Either it is not closed properly (user error or a blockage) or the locking mechanism has a fault. Check to see that there is no object shoved in the latch hole (our 2yo just did that) preventing the door from closing properly. If it is not that, a technician is advised. I tried to get into the machine to fix out issue but could not get to where the issue is.
Posted on Nov 22, 2009
Anonymous
SOURCE: error code F 21
I have a Bosch Classixx 6 1200 express washing machine showing error code F21 on the display, what is it?
Posted on Mar 10, 2010
paulrobin177
SOURCE: Bosch Error Code 13 Washer won't drain
First, unplug your washer. After that find the little round plate below your drum opening on the exterior of the washer. It should have a small hole in it. Use something to gently push trough this hole and twist the cover off, Inside there you will find the drain access. Be careful, if there is water in your drum this will make a mess when you unscrew the drain access. Take the usual precautions and unscrew the drain access slowly until it is off. Remove any obstructions and replace access door and cover. Clean up any mess and plug back in your washer and try again. takes about thirty minutes to an hour depending on how much water is in the drum.
Posted on Sep 21, 2010
mel_hoyle
SOURCE: Bosch Exxcel Washer F21 error code
got a bosch washing manchine it keeps coming up f21 error and i have no book 2 see wot it is can you help me by tellin me wot it is thanks
Posted on Nov 29, 2010
I have a hoover vhd 9163zd with error code E05,what component does it refer to being at fault,where is the component located
Error Code 05 is a NTC fault, either open circuit or shorted.
If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, the "E05" error code will be displayed.
Possible Causes / Procedure:
1. Unplug washer or disconnect power.
2. Check the water temperature sensor. Check connections to the water temperature sensor.
3. Check resistance of heating element, if present on this model. (abnormal = infinity).
Replace failed component. It could be the sensor or the temperature control module (NTC module).
Good luck.
Apr 20, 2015 | Hoover Washing Machines
I was receiving an F3E2 Error code which states something to do with the water temperature sensor. I got a new water temperature sensor and replaced. Now the washer will run fine without any clothes in the...
WATER TEMPERATURE SENSOR ERROR
If the water temperature sensor (NTC) value is out of range (23°F to 217°F
[-5°C to 103°C]) during the water-heating step of the WASH cycle.
Possible Causes/Procedure
- Unplug washer or disconnect power.
- Make sure that connections to water heater & CCU (TH2 & HE2 cavities)
connectors are not broken or with wires detached, and that connector internal
pins are visible.
- Check continuity from the water heater sensor (black wires) to CCU
(TH2 cavity) connector.
- If the continuity diagnosis failed, the Main Harness must be replaced.
- Check the resistance of heating element.
- Check the resistance of the water sensor.
- Plug in washer or reconnect power.
- Verify the washer operation by running the Diagnostic Test cycle.
- After the diagnostic test has finished, unplug washer or disconnect
power and wait for 15 seconds.
Water Temperature Sensor
2. Disconnect the wire harness from the water temperature
sensor and measure the resistance of the sensor. Use the
following table. An abnormal condition is an open circuit =
infinity; Water Temperature Sensor must be replaced.
Temperature Results
32°F (0°C) 35.9k ?
86°F (30°C) 9.7k ?
104°F (40°C) 6.6k ?
122°F (50°C) 4.6k ?
140°F (60°C) 3.2k ?
158°F (71°C) 2.3k ?
203°F (96°C) 1k ?
Nov 25, 2014 | Washing Machines
Needs Service code 136
136. (10001000) Motor Stall
The Motor Control Module has been unable to start the motor. Possible causes of this fault
are: Faulty motor harness, faulty or jammed motor, seized bearings or seals, faulty Motor
Control Module, faulty Rotor Position Sensor or harness.
Primary Source: Wiring.
Action: Measure/check the motor harness, connectors and motor for
discontinuity. This can be done by taking a resistance measurement
between phases of the motor harness at the Motor Control Module
end. Nominal resistance should be around 32Ohms.
Secondary Source: Motor.
Action: 1) Check free rotation of the agitator and basket by rotating by hand.
Bearings and seals may be seized.
2) Check the Rotor Position Sensor and associated harness for
water, mechanical damage or corrosion.
Tertiary Source: Motor Control Module.
Action: If the primary and secondary checks pass inspection, then replace
the Motor Control Module.
Jul 16, 2012 | Fisher and Paykel Fisher Paykel Intuitive...
Wont finish cycle - keeps going with 1 minute still to go...
Hello there,
Long or endless wash cycle times indicate a fault in the water heating circuits. The water heater, NTC or the control module are the likely culprits. Some minor dis-assembly and testing will be required to determine the exact cause of the fault. Please can you answer the following simple questions to assist me in solving your problem:
1. Is the water heating?
Start a regular wash cycle, let it run for about 10-15 minutes, then open the door and check for steam or test the water temperature in the bottom of the washer by hand. The water should be hot, not luke-warm.
2. Do you have an RCD fitted in your consumer unit? (fuse/breaker box)
3. Do you have a Torx T20 screwdriver and a multimeter - these will be required for any testing and/or repair.
If your simply looking for a diagnosis and some idea of repair cost, the water heater and the control module are about £100 each to buy. The NTC is about £20 but this is less likely to be the cause of the problem. Labour charges will be extra. The control module can sometimes be repaired with a relatively simple re-soldering of the heater relay pin/s.
All of the above can be replaced on a DIY basis, but the water heater and NTC are best left to a professional.
If you need further assistance, please let me know the answers to the above questions.
Regards,
BElectric
Mar 16, 2011 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
136 CODE SHOWING f p washer
136 code (10001000) Phase 1 to 6 - Motor Stall The Motor Controller has been unable to start the motor. Possible causes of this fault are: Faulty motor harness, faulty or jammed motor, seized bearings or seals, faulty Motor Controller module, faulty Rotor Position Sensor or harness. Primary Source: Wiring. Action: Measure / check the motor harness, connectors and motor for discontinuity. This can be done by taking a resistance measurement between phases of the motor harness at the Motor Controller module end. Nominal resistance should be around 12.2 ohm for Phase 2,3 & Phase 4. For Phase 5 and 6 onwards the nominal resistance should be around 32 ohms. Secondary Source: Motor. Action: 1) Check free rotation of the agitator and bowl by rotating by hand. Bearings and seals may be seized. 517765 March 2004 - 41 - 2) Check the Rotor Position Sensor and associated harness for water, mechanical damage or corrosion. Tertiary Source: Motor Controller module. Action: If the primary and secondary checks pass inspection then replace the Motor Controller module.
Jan 17, 2011 | Washing Machines
F05 flashing - NTC needs replacing ? I need a diagram to know where to remove it and replace it
"F05" is an indication of a water temperature sensor (NTC) error, or Heating Circuit failure. Check the Water Temperature Sensor and check connections to the Water Temperature Sensor. To access, you will have to UNPLUG your washer and remove the lower access panel under the door. The panel comes off by removing the screws under the bottom edge. HINT: If you place a block of wood under each front foot of the washer, it will make access to the screws much easier. If the panel sticks, a tap on the sides will knock it free. The panel will drop down then come off. The sensor (NTC) is located at the base of the wash tub in the front on the heating element. This will be a small square shaped plug between the heating element terminals. Unplug the wire harness and take a resistance check. Readings will be as follows:
Temperature Meter Reading
32°F (0°C) 35.9 K ohms
86°F (30°C) 9.7 K ohms
104°F (40°C) 6.6 K ohms
122°F (50°C) 4.6 K ohms
140°F (60°C) 3.2 K ohms
158°F (70°C) 2.3 K ohms
203°F (95°C) 1 K ohms
Roughly...around 9K ohms at room temperature if I'm reading the chart correctly. Take readings as listed and also double check the connector to make sure it is not oxidized. Try cleaning the plug and reconnecting to see if the error code goes away. If not, you will probably have to replace the sensor. If the sensor checks good, take a reading across the heating element terminals. It should indicate about 15 ohms.
Lastly, remove the washer top panel by removing the three screws holding the panel in place in the rear. Once the screws are removed, slide the panel back then off. Locate the Central Control Unit (CCU) directly behind the wash tub. Take a resistance check at the Heating Element Solenoid by removing connector 9 from the CCU (this is the second connector from the RIGHT as facing from the front). A reading across test points 1 & 2 should also read 15 ohms
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&&&&
Jul 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Start wash runs for aprox one minute goes in to f05 mode hit pause and open and close door hit start goes through cycle?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@@@@
Jun 15, 2010 | Kenmore Elite 45986 Front Load Washer
My washing machinw is displaying f-03 and wont wash?
FO3 indicates that the wash thermistor is open or short circuit.
Check the connections to the thermistor and the heater element.
Hopen this helps.
Dec 15, 2009 | Hotpoint Ultima WF860 Front Load Washer
Water not heating,element testing ok
Hi there
if element changed recently when it failed it may have damged heater relay on back of control module if the heater or this has failed you will only get a cold wash on any prog they will take nearly four hours to finish if it takes normal time to wash but doesnt heat will probably be an ntc fault this is attached to heater and easy to replace.
Dec 13, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Washer is leaking tremendous amounts of water. also it is giving 2 codes F05 and FH
F05 error is an indication of a water temperature sensor (NTC) error, or Heating Circuit failure. Check the Water Temperature Sensor and check connections to the Water Temperature Sensor. To access, you will have to UNPLUG your washer and remove the lower access panel under the door. The panel comes off by removing the screws under the bottom edge.
Suggestion: If you place a block of wood under each front foot of the washer, it will make access to the screws much easier. If the panel sticks, a tap on the sides will knock it free. The panel will drop down then come off. The sensor (NTC) is located at the base of the wash tub in the front on the heating element. This will be a small square shaped plug between the heating element terminals. Unplug the wire harness and take a resistance check.
The ideal readings should be
Finally, remove the washer top panel by removing the three screws holding the panel in place in the rear. Once the screws are removed, slide the panel back then off. Locate the Central Control Unit (CCU) directly behind the wash tub. Take a resistance check at the Heating Element Solenoid by removing connector 9 from the CCU (this is the second connector from the RIGHT as facing from the front). A reading across test points 1 & 2 should also read 15 ohms.
I hope this information if found to be helpful.
God Bless
Jul 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Bosch Nexxt 500 WFMC3301 Front Load Washer Logo
492 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
peter gittos
peter gittos
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
