SOURCE: White Westinghouse upright freezer not cold enough.
Coils are probably underneath. remove the grille at the front (usually you just rotate it down to pull off) and then vaccum inside with a wand. If there aren't any coils there either, pull the machine out from the wall, and remove the lower panel from the back side. Inside you should find a fan next to a coil. Make sure that fan is working, and if it isn't make sure it is getting power.
Vacuum out as good as you can, and if you can use compressed air to blow it clean, even better (vacuum first because it will kick out a lot of dust).
If vacuuming the coils doesn't work, then you probably have a freon leakage problem, in which case it is probably not worth the cost of repair.
SOURCE: Freezer compressor runs steady & getting -30F
You probably have a defective thermostat or sensor for reading the temperature.
SOURCE: Red alarm light is on on Westinghouse upright freezer
Most probably during transportation either the coolant(previously freon gas) may have leaked out so the pressure on the cooling pipeline causing the red alarm because the compressor will overheat if the fridge is kept running at very cold thermostat readings and no effect of cooling the fridge will ultimately result in the compressor getting burnt. However fist have look at thermostat setting knob which could have loosened during transportation and just pushed into the spindle without knowing the correct angle, thus even though it looks as if on high cool but could also be the lowest setting..........sodeep
SOURCE: Freezer not freezing, refrigerator warm, hear clicking sound
The overload/relay on the compressor is shorted . This is the piece with 2 or 3 wires connected to it , mounted on the compressor . The part # you need is 8201786 . Complete mounting instructions , come with this kit . Easily replaceable .
SOURCE: I have a westinghouse silhouette frost free
THE COMPRESSOR IS NOT WORKING ON YOUR REFRIGERATOR..
