SOURCE: indesit WIL103 flashing lights problem
because of the short time this runs then stops, there could be maybe 3 faults, 1 check water inlet valves and supply for water flow 2 check for any motor action (use another programme) 3 check heater element for open circuit number 1 or number 3 sounds most likely hope i have helped, if so rate me please
SOURCE: Indesit WIL143S flashing lights
hi have you unplugged your washing machine for 2 mins then plugged it back in to give the machine a reset..its says it in my WIL 163 MANUAL TO DO IT was wondering if your is the same gl
SOURCE: Indesit 1000 cycle starts but then lights flash
Check the filter which is under the white panel at the front of the machine(the filter is in the lower right hand corner). Unscrew the filter and remove it. Mine was blocked with loads of grease/limescale. I cleared it out and the machine is as good as new again. I cleared the system with half a packet of soda crystals put into the main drum (on its own without any washing in!) and did a wash at 90degrees. Its as good as new now. Good luck. CK
SOURCE: Indesit WIL153 Door lock LED flashes with 2 other LEDS
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
SOURCE: INDESIT WIXXL 146 washing machine ( please help
It appears your timer/main controller/CCU has failed in this instance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
