MG2900 series printer/scanner
Guide to Canon Pixma mg2900 Wireless Printer Setup
This printer caused a lot of pain and frustration to many individuals. It turns out to be fairly simple to set it up, it's just that there's really no documentation anywhere.
So, one helpful user lastly shared the measures after several customers were able to effectively set up their Canon MX2920 printer after calling for Canon assistance. Here are the steps: First, we need to connect your printer to the web.
You would normally do this by downloading to your Windows or Mac computer some setup software, but obviously we can't do that. We're going to have to use the WPS technique:
Connection Using WPS (PIN code) for Canon mg2900 wireless setup
Online Manual MG2900 series MG2910 MG2920 MG2940 MG2950 MG2960 MG2970...
Try this link and see if we found the problem? Thank you Karen and could you please leave feedback for I am fairly new at this?
SOURCE: Canon Pixma MP830 error 5100
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
SOURCE: Power Lamp Flashes Green and Alarm Lamp Flashes 7 TIMES
Count how many times blinks orange lamp and check this error in this forum.
SOURCE: Canon Pixma MX300 - error code 5B00 - check
Try it works for most Canon
Hi you can try
Solution:
All The Best: Pineworks
SOURCE: Canon Pixma MP140 freezes, only alarm lamp is on, no code error
Troubleshooting
An Error Code
Is Displayed on the LED
Power Lamp
Flashes Green and Alarm Lamp Flashes Orange Alternately
(go down the page until it says:
Orange Alternately
)> then look for the error code. good luck!!sorry, the system is printing the same font as the book.
