Question about Coleman Camping, Backpacking & Hiking
Where can I find a replacement battery for a Coleman lamp? Battery is a Fifutec sealed lead-acid rechargeable JL3-XMAS (6V-4AH)
Twin tube fluorescent. Has not been used for a long time. Charged 24 hours and would not light.
    Habit-Forming:
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
Amazon sells applicable versions $12-15..
Posted on Jul 02, 2018
    Top Expert:
  • Coleman Master
  • 53,755 Answers
Take it along as a sample to any battery shop and they will have a battery to suit
Posted on Jun 30, 2016
6ya staff
SOURCE:
How to change batteries in A Eveready FAB4DCM
had a quick look online and found this is a museum piece.
http://www.flashlightmuseum.com/Eveready-Flashlight-FAB4DCM-Red-Black-Sea-Beam-Waterproof-Lantern-6V-2003
Called a Dolphin torch, I remember these from the '80s and had to replace the batteries too often to ever want to do it again.
The front unlocks by rotating 1/4 turn. The batteries are a 6V sealed lead acid cell and now cost more than a new modern torch with a Li-ion cell. You will need a 6V charger if the battery can be recharged and unlikely if its old and discharged for long time.
Aug 11, 2018 | Eveready Camping, Backpacking & Hiking
I need to replace a fifutec sealed lead-acid rechargeable battery [12v -2.8ah]
http://www.atbatt.com carries a large array of sealed lead acid batteries. I did a search for 12V 2.8ah and here is one of the results:
http://www.atbatt.com/sealed-lead-acid-batteries/b/interstate/m/interstate-12v-2-8ah.asp
May 22, 2015 | Camping, Backpacking & Hiking
Where can I purchase a charger and manuel for a EZ Rider Wild Child Motorcycle
you could try the original supplier or ebay and failing that you could try searching online for a pdf manual and just buy any charger that is the correct type voltage and most importantly polarity, having looked at the bike its a childs harley type bike and is 6v 4ah and likely a sealed lead acid type so i would buy a 6v 500ma lead acid charger, if there is a charge port you will need a plug to match and you will need to check the polarity is correct or if there is easy access to the battery terminals you could just use the crocodile clips to the corresponding terminals on the battery itself there is a selection of chargers here 6V Lead Acid Battery Charger eBay a 500ma charger will charge the bike in 8hrs the higher the ah the faster it will charge but i wouldnt go much higher than 500ma without checking with the vendor that it is suitable for a 4ah battery hope this helps
Feb 22, 2014 | Toys
Battery will not recharge and if bad can I replace battery?
I believe the replacement battery is a CA645 - 6V4.5AH/20HR. You can check your particular model number at: http://www.batterymart.com/p-6v-4_5ah-sealed-lead-acid-battery.html
Nov 20, 2010 | Vector 1 Million Rechargeable Spotlight
My Vector model #VEC117FS has a battery that is dead and will not recharge. The replacement battery is VEC 191 according to the owner's manual. Where can I buy this battery or is it best to just buy a new...
There are many companies on the Internet that offer Sealed Lead Acid Batteries, which may be less expensive than replacing the light. I would suggest identifying the particular battery your light has and then check what's available on the Internet to make a decision on whether it is cheaper to replace the battery or the light.
http://www.batterywholesale.com/battery-store/SLA-batteries
http://www.batterymart.com/c-sealed-lead-acid-batteries.html
http://www.atbatt.com/sealed-lead-acid-batteries.asp
http://www.zbattery.com/Batteries/Sealed-Lead-Acid
http://www.planetbattery.com/product.asp?id=10
Nov 10, 2010 | Vector 1 Million Rechargeable Spotlight
I have a b&q rechargeable 1m candle power lantern, how long do I leave it on charge from being flat as the charger unit does not have a led incorporated in it.
Probably between 3 to 5 hours.
Check battery regularly. It should be warm while charging. When it begins to get hot it is charged. If you charge the battery for longer, there is the increased danger of fire or leakage from the battery.
Note how long the battery has been charged for and during for future charges, reduce the charging time.
NiCad batteries should be run flat before being recharged rather than being topped up in order to get maximum life out of the batteries. This is less critical with NiMh batteries.
Sep 28, 2010 | General Hand Tools
I don't know where to get a replacement battery? It shows SEL CB4-6, (6V 4AH/20HR) on the battery itself?
The replacement battery can be purchased from almost any electronic shop, Radio Shack or online at www.batterymart.com/p-6v-4_5ah-sealed-lead-acid-battery.html
Aug 10, 2010 | Vector 1 Million Rechargeable Spotlight
I need a replacement for the 3 sealed lead acid batteries in the Black & Decker "Simple Start". It sat too long & sulphated. The batteries are "SEL C83-6"
In March, 2006, Black & Decker purchased Vector Products, Inc. Since the acquisition, Black & Decker has assumed the manufacturing of all Vector products. For customer service and warranty information for Vector products, please contact Black & Decker Customer Service. Or, you can order a replacement battery from: www.batterymart.com/p-6v-4_5ah-sealed-lead-acid-battery.html
Jul 31, 2010 | Vector 2M Pwr Rch Spotlight
Camping, Backpacking & Hiking Logo
1,155 people viewed this question
Top Coleman Camping, Backpacking & Hiking Experts
Marvin
Marvin
yobo007
yobo007
oldhess
Are you a Coleman Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
