Kenmore Elite 45986 Front Load Washer Logo
Laurent Grangien Posted on Jun 24, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I started the program and realize 15 minutes later it was the wrong one I spaused it and now I cannot start again
MS_WI_3013
Level 2:
Habit-Forming:
  • Expert 119 Answers
  • Posted on Jun 24, 2016
MS_WI_3013
Expert
Level 2:
Habit-Forming:
Answers
119
Questions
0
Helped
45851
Points
196
Before digging further, lets try unplugging the washer from power for 3 minutes, then plug it back in, turn it on and select a cycle and try starting it.
1helpful
01 durango 4.7 starting problems. was driving then car just died. then about 10 minutes later it started and ran for a couple of days. then it ran and then died again
There's a website that has all this information about all this and manuals everything totally free there are many actually but I personally like few reliab le-store for eg. .. let me know if u need help
thanks
2002 Ford Explorer will not start. Theft light flashes and makes a continuous ping noise.
This happens if you put the wrong key in accidentally. Get into the Explorer and insert the known correct key into the ignition and turn it. If you use the wrong key, such as one that was cut to open the doors, the system will remain armed. If the car then starts, then you have disarmed the anti theft system. If not, move on to this: Ford Explorer keys have large black plastic, or molded rubber, heads. Inside the head is a transponder chip that is programmed to a certain code so that the transponder recognizes the key. When you are sure you have the correct key, try to start the car with the spare, if you have it. If the car still refuses to start, move on to next step here: Wait 15 minutes, until you see the flashing rate on the red light on your dashboard decrease to normal speed and then try both keys again. If this still fails to start the car, raise the hood and disconnect the battery for 15 minutes, then reconnect it and try again.
1989 corvette cuts off when running for 10 minutes. starts up and shuts off immediately afterwards. sits for 15 minutes and the cycle repeats itself
could be the security system. is the key an original or one made later? the keys have a chip that must be programmed to the particular vehicle. try turning the key to on wait i think 15 minutes the turn the key off then try to start.
My 97 expedition starts and runs good I'm driving down the road, Then the overdrive light starts blinking on the end of the shifter, So when I come to a stop then start to go again it shifts real hard....
With the light flashing ,codes are stored in the transmission control module . Have the codes check an this will tell you whats wrong . Probably a sensor or shift solenoid or line pressure solenoid .
1helpful
I was driving down the street and the signal lights both stop functioning .. Parked car and was gone approximately 15 minutes. Started car and my signal lights are functioning again. Make a 2 minute stop...
Check your battery terminal's, check woltage when engine is off on your battery, check voltage when running. Could be alternator, battery ior something wrong with charging system.
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Kenmore 80 series dryer stoping after running for 10 to 15 minute
Start any cycle. Dryer runs for 10 to 15 minutes, then stops before cycle is complete. Start again, stops again in 10 to 15 minutes.
Alexander
vince
