SOURCE: Bernina Virtuosa 150 and uneven layers or bulk.
Hi I have a 15 year old Frister Rossmann serger which I got second hand 10 years ago. It has had one break down which was my fault for not getting it serviced for 8 years. Not sure where in world you are. They sell as Frister Rossmann in UK and Europe and Kenmore in the US. I've used it mainly for dressmaking and soft furnishing projects. One more thought on the Bernina have you tried leaving a query / searching on the US Bernina website www.berninausa.com I use them alot. Try and stick with getting the Bernina sorted, I love mine! Fiona
SOURCE: bobbin thread wont pick up
Be sure needle is inserted correctly with the flat side in the proper position. Rethread the machine and try again. If it still won't work you have a timing problem which requires a technician or a good mechanic.
sewman7
SOURCE: Bernina Virtuosa 160
First the simple solution. Make sure your needle is inserted flat side to the back and all the way up.
The only other thing I can think of is that your hook is out of time and this will take a technician to re-time it. You may need to take it in for a servicing.
SOURCE: My babylock makes a clanking noise and the yellow
As I was required to pay for your advise which may not have worked anyway I opted to take my machine to be serviced. Thank you
SOURCE: Sewing thick fabric and machine won't send it through
Sergers are not really meant to sew very thick material. The blades have a maximum amount of range, or thickness that they can reach to cut. If you go outside that range, get ready for a big repair bill! You can break loopers and even the needle plate when you "push" a serger. My advise would be to use you sewing machine for the, "pounding" work. The type of material matters too, A thick Quilt like fabric can be sewn becatuse it's not dense material. A thinner harder denim could max out at 3 layers because of it"s hard finish. If the fabric you're sewing isn't dense like, you could just need new knives.
