My car developed gear problem. The 4LO was blinking, check engine sign permanently on. On Drive mode the vehicle behaves as if on Neutral. It moves with occasional drag when driven in the morning until temperature rises n it no longer moves. Installed a Belgium uses gear n thereafter dat while driving gear selects up to gear six but d moment l slow down the vehicle doesn't accelerate until engine is turned off n restarted. Presently if u put gear in Drive and Neutral it moves forward, if u put it in Reverse it remains still doesn't move. Could Brainbox be responsible for this anomaly or the gear still requires replacement
Hi, it could be the engine going into limp mode because you have not had the issue associated with the illuminated warning light checked out. Thiis clearly needs to have an OBD scan carried out by a qualified, experienced technician. You can obtain an OBD scanner from many suppliers if you wish to carry out the procedure. Look up the procedure for getting any fault codes and then either do the work yourself or engage the services of a decent mechanic.
The engine light warn when the computer / ECU senses something wrong. I t can send a signal to the gearbox not to allow gear enagement at all pr limit the vehicle to low speed. Have this checked first, it might not be a gearbox issue at all, if the problem is not resolved please add more detail and repost the query.
Testimonial: "Thank you. The fibre of the original gear was observed burnt hence a Belgium used was installed. Still the problem persisted. Pls refer to my earlier post."
