Try a reset to factory default and then setup from scratch before anything else.
Can I suggest that you obtain a quality surge protector..
If the reset is no good please repost. Also, turn the power off for all devices attached to the tv for a few minutes before attempting the reset.
SOURCE: hdmi not working
http://www.pioneerelectronics.com/PUSA/Support/HomeEntertainment/ch.PlasmaTVs+Monitors.SupportFAQ
Cut n paste
SOURCE: HDMI ports do not work after lightning storm
Probably not, but your insurance should pay if you have a renter or homeowner policy.
SOURCE: i have a vizio 55
I am having the same issue with our Vizio E550VL TV. Does your TV show No Signal on the screen? I was able to get regular AV to work with the Yellow, Red, and White cable to work but none of the HDMI ports would not work. If it does not power on at all it may be the power supply. I had to order the main board to get it to work correctly. Vizparts.com is where you can order it from.
SOURCE: Panasonic Viera TC-L37X1 hdmi not working
What do you have hooked up to the HDMI ports? Just a cable box?
yes the board is available at the following link http://tvrepairworld.com/sony_lcd__plasma_tv_circuit_boards
the board with the HDMI on it is listed as the Sony FB3 Board 1-873-850-14
