SOURCE: tsr mach3 conditioner
The smell is because of the stuff growing inthe water from the air conditioner. When you run the a/c it keeps the water condensed on the coil. When you turn the a/c off and run just the fan, it allows the water to warm up and start evaporating thus allowing the goodies in the water to become airborn. It would be adviseable to have the unit disassembled and cleaned by a professional due to the obvious danger of mixing water and cleaning chemicals with electrical equipment
SOURCE: coleman tsr rv air conditioner leaks into rv when running
It probably has a clogged condensate drain. Take off the cover on top the RV and check hoses or tubes leaving unit for debris or lint. Often this water is used to help cool the condenser so look for leaves pine needles etc in the pan. There may be a cover you can remove on the evaporator section that will allow you to clean the collection pan and hose or trough. Is it possible the RV is far enough out of level that the condensate can't "run uphill"? Always power off while working on this unit unless you are electric savvy. Good luck!
SOURCE: coleman mach air conditioner in rv tries to start
“The voltage could be low – ”
a) Check the voltage between #1 on the
overload switch and the “R” terminal of the
compressor while it is not humming. This
voltage must be 115 volts domestic USA
models or 240 volts export/overseas models.
No less than minus 10% is allowable.
b) Check the voltage from “C” or “R” of the
compressor while it is humming (trying to
start). The latter reading will probably be
lower, but it still must be 103.5 volts
minimum domestic USA or 216 volts
minimum export/overseas models.
If the first reading is above 103.5V domestic USA and
the second is under 103.5V domestic USA, there is
too much voltage drop in the lines - a situation which
must be corrected for the air conditioner to perform
safely and satisfactorily.
2. “A capacitor could be shorted, weak or open.”
Turn the power off.
Caution – There is always a chance that a capacitor is
holding a residual charge, so before touching a
terminal, discharge the capacitor as explained earlier
in this booklet.
Remove capacitors, visually examine them and test
them per instructions given in earlier section on
capacitor testing (See page 9).
If the capacitors test OK, replace them and carefully
reconnect the wires. Be sure the wires are connected
to the right terminals.
3. “Start relay contacts could be open – ” if so equipped.
Turn off all power, then check for continuity with
ohm meter between terminals 1 & 2.
4. “Compressor start winding could be open or
grounded.”
Check compressor windings per instructions. See the
section on the compressors (See page 8).
5. “Compressor could be mechanically stuck.”
This very rarely occurs and when it does, it is usually
after a lengthy shutdown. This should be considered
only after all the above possible causes have been
positively eliminated. To free a stuck compressor, use
your hermetic analyzer according to the
manufacturers instructions.
SOURCE: RV PARTS AND ACCESSORIES. Best Prices Online.
Check out this website they have a great online rv parts catalog and what is great about this business is if they do not have the part they will find it for you. Never heard of anyone else providing this service but they do and this is why I use them for ordering rv parts for my rv business and my customers.
The website is www.arvparts.com
The Office # is 1-702-762-3428
Hope This Helps!!!!
Testimonial: "THanks for the referral"
SOURCE: i have a 3000 watt generator, will this run the
It should, but what have you got for plug ins on generator? 30 amp, or 15? I believe the rough estimate is 100 watts , equals roughly 1 amp.
