Sewing Machines Logo
W
Wendy Garland Posted on May 31, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What do I have to do to fix the tension on my machine? I am getting lots of thread loops etc on the underside...so I'm assuming it is a problem with the tension on the top.
R.A. Ellis
Level 3:
  • Sewing Machines Master 12,731 Answers
  • Posted on Jun 01, 2016
R.A. Ellis
Level 3:
Answers
12731
Questions
Helped
2613362
Points
59176
Most often, thread looping under the fabric is either because the upper thread is not seated in the tension disk, it is not threaded correctly, or the upper tension is too loose.
Be sure to install a brand new needle.
Remove all the thread. ALWAYS RAISE the presser foot during the threading process. This releases the tension disk and allows the thread to seat completely in the disk. Rethread from the beginning. Confirm the thread path is correct.
Set the upper tension to the midway point.
Retest your machine. You may need to tweak the upper tension to get it where it should be. The ideal tension is when the upper and bobbin threads meet in the middle of the fabric.
Debbie
Level 3:
  • Sewing Machines Master 1,860 Answers
Debbie
Level 3:
Answers
1860
Questions
0
Helped
384507
Points
9030
Make sure the presser foot is lifted to it's highest position and adjust the top thread tension, the lower the tension number the looser the thread and the higher the number the tighter the thread
Needle stitch fine. Bobbin stitch loops.
First, try a brand new needle.
Second, consider using a better quality thread. By all means, AVOID old or bargain bin threads. Coats & Clark used to be a standard, but thread quality has improved over the past few years, so you may want to check out other brands like Aurafil, Superior, Isacord, etc. Also, cotton wrapped polyester thread releases thread lint that contributes to build-up of gunk in the machine. Some sewists have noted that they experience more sewing issues when using C&C threads. However, some machines will do better with certain thread brands than others, so some experimentation may be beneficial.
Third, check the stitch on your sample again. Generally, when thread loops appear on the underside of the fabric, it is the upper thread that is the problem. If loopy threads appear on the top of the fabric, it is the bobbin thread that is the issue. You can even use a different color in the top to help distinguish which thread is the problem.
Fourth, when threading the upper thread, Always Raise the Presser Foot during the threading process so the tension disk is released and the thread can seat properly. "Bird nesting" occurs when the thread is not seated in the tension disk.
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
Fifth, when the upper thread appears on the underside of the fabric, the upper thread tension is too loose. If the bobbin thread appears on the top of the fabric, the tension thread is too tight (or the bobbin thread is loose). Start out with the upper tension set at the midway point and tweak it from that point. The tension is ideal when both upper and bobbin threads meet in the middle of the fabric.
Also, remember that tension is not static--a tension setting for chiffon will most likely not work on cotton or denim. Get comfortable adjusting the tension to suit the project you are sewing.
Machine isn't sewing right. Underside thread is very loopy. Was sewing fine but thread jammed in bobbin area.
Remove all remnants of the thread from the bobbin area.
First thing first - thread inside bobbin should be tightly wound in. Insert bobbin into bobbin case and thread through slot and under the spring. Spring has small screw which regulates the tension. Hold the lot by thread like yo-yo and jerk a little down-up. It should drop just a little (not run down) - that is usually required bottom thread tension,
if not, regulate with the screw. Set top thread tension 3 and sew. If still looping under, increase the top tension higher till the looping disappears. Also try new needle.
Juki DDL 8500: Bobbin thread is not coming up to the top side and the top thread is looping on the underside. Bobbin thread slides right out, and I've had no luck adjusting the top thread tension.
What thread are you using and what are you sewing? I'm assuming the machine is stitching correctly and it is just a tension issue. I would test each thread seperatly by hand and see if one thread is too tight or too loose. Thread on the bottom usually mean the top thread is too loose however it could by the bobbin is too tight. It could also indicate a slight timing issue or a burr on the hook. Is the thread shredding or getting damaged?
1helpful
I keep getting tiny loops on the underside of the fabric when sewing. I have just had the machine serviced and it was fine for a day. Changed the bobbin case and adjusted tension I had to have tension set...
It seems to be a tension problem, if the loop is underside its usually a greater pull from the underside thread, whether for bobbin thread tension too tight or upper tension too slack. As I told my late mom after reading her machine manuals, unless you are a service pro, don't mess with bobbin tension (if you have to, mark the original screw position and use specific 1/4 turns or 1/8 turns to check), just make small adjustments in your tension dial and check for results. I it requires an unusally high tension there is no choice but adjusting lower tension by yourself or in the service shop
HD 3000 loops underneath work
It's most likely not the machine. It's the other things, ie needle, thread, etc. combination. For sewing knit, be sure to use a ball point needle. The needle eye size is important to so the thread is neither too small nor too large for the thread weight.
FWIW, it sounds like bird nesting. --the thread is not seated completely in the tension disk. Remove the top thread from the machine and ALWAYS RAISE the presser foot when rethreading!
Also, check that the tension is appropriate for the project. The two threads should meet in the middle of the fabric. If there is top thread showing on the underside of the fabric, the top tension is too loose. Tighten it until it until the top thread pulls the bobbin thread up into the fabric.
All About Needles SCHMETZ Needles
The top stitch is perfect but underneath the material there are many loops. I am assuming this is from the bobbin. How do I correct this?
no, more likely your top tension is too loose causing the loops on the underside of your fabric, loops on top would be bobbin too loose. raise presser foot and rethread top thdead pulling thread into tension fully. set top tension dial to 5 and test sew. if still looping underneath try tightening top tension by turning dial up to 6. but usually top tension should only need minor adjustment tweeks. you can test top tension by lowering pressure foot to engage tension and holding thread just above needle thread guide, pulling thread downwards . there should be resistence on it to your pull. if you cant feel any then tension device may be faulty, and require service.
1helpful
BOBBIN TREAD LOOPING UNDERNEATH
looping thread on the bobbin side means that the upper tension is too loose... make sure it's threaded correctly.
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
