Question about Clothing
How to get power with diferent transformer on my jbl encounter
Cant get to get it to get power can i hook up to a diferent system
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 66 Answers
Need another one
Posted on Jun 20, 2017
6ya staff
SOURCE:
Jbl eon 518s power trip on stabilizer/transformer
hell no thats a fire hazard.. I am thinking that the surge is more that that unit can handle..surge is the extra power needed to start up an electrical piece of equipment..surge can easily double the amount of power required for startup..may need a new powerstrip with a much heavier rating..
Jan 12, 2014 | JBL EON 518S Subwoofer Speaker
Cant get music to play on JBL speaker from my phone
What type of JBL speaker, how is it hooked up and does the phone work with other speakers?
Aug 18, 2013 | JBL Audio Players & Recorders
Is there a replacement amp for my jbl SCS180.6S subwoofer? I tested the speaker and it's fine. I also tested the output from the stereo and it is also fine. When the sub is turned on, there is a b
No you can't! I should contact JBL for the location of the part. Transformers are safety parts and should only be replaced by the same part or those approved for use by the maker of the unit.
Dec 20, 2012 | JBL Audio Players & Recorders
Loud buzz/hum started on jbl eon 1500 powered speaker one side only after power cut off and sudden power back on makes same noise on it`s own as well as with mixer etc could this be a transformer...
For some reason the soft on protection circuit has failed. it is not a simple fix and would require the amplifier module to be removed from the speaker to assess the damage.
Mar 10, 2012 | Jbl Eon 515 Eon515 15 Powered Portable...
I can not increase or decrease volume on my JBL encounter speaker system
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
hope this helps
Apr 11, 2011 | JBL Encounter 2.1 Computer Speakers
Have a JBL Encounter 2.1 Multi Media Speaker System need to find a power lead and speaker jack for it im resident in uk and need voltage requirements regards
you shouldnt have to worry about a speaker jack for it. it should work anywhere and a simple usa to uk power adapter will work for you it just changes the plug type and up or downs the voltage (i cant recall if uk is higher or lower then the u.s)
Mar 23, 2011 | JBL Encounter 2.1 Computer Speakers
I have a power problem with my JBL Encounter system. Since I played it very successfully on Saturday night with some marvellous music, it is no longer working. I have check the fuse in the plug and...
Hello
its power supply section has failed. you have to look into it for further trouble. Replacing fuse or line chord won't give you any result. you have to check wit whether the transformer faulure has occured or not. If it is fitted with a mains transformer, it will have a thermal fuse in it imbeded in between its primary and secondary windings placed inside the transformer and can be accessable if it is taken out. It is meant for to block the transformer woring, if it does overheats due to long run at high volume. Check from this and proceed. you must have a sound knoledge in electroncis and have a concept of soldering to do this work. OK.
Mar 22, 2011 | JBL Encounter Speakers Computer Speakers
No power when turned on. led light does not show, changed fuse in plug, is there anouther fuse inside the system?
N450AD transistor is busted,no available!!! does anyone have any idea for "replacement/subtitutions" for this Transistor?
Please help!!!!!
Feb 02, 2010 | JBL Encounter 2.1 Computer Speakers
Jbl car audio system
You may have accidently hooked the AMP up to a constant power supply. You need to hook the power for your amp to either the unit (because it is on intermittent power supply) or find an accessorised power supply for it separately. Go to this site to see if you cant rewire your AMP.
http://www.ehow.com/how_5829_wire-car-stereo.html
Mar 26, 2008 | Car Audio & Video
JBL Creature 2 Blowing Fuse
There will be a short somewhere in the power supply. If you replace the fuse it will blow again. You COULD try a larger ampage fuse, but any electrician would not recommend this!
Oct 15, 2007 | JBL CREATURE II Computer Speakers
Clothing Logo
1,524 people viewed this question
Top Clothing Experts
ray gallant
ray gallant
Andrew Taylor
Andrew Taylor
Bill Boyd
Are you a Clothing Expert? Answer questions, earn points and help others
