Magic Bullet Nutribullet Blender Logo
M
Mary Carr Posted on May 25, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mine has stopped working. it makes a sound though. i bought it about 2 years ago. is it covered by guarantee and where can it be repaired in WA
R.A. Ellis
Level 3:
  • Master 12,731 Answers
  • Posted on May 25, 2016
R.A. Ellis
Master
Level 3:
Answers
12731
Questions
Helped
2613556
Points
59176
You might consider the cost to repair vs purchasing a new one. Depends on the model, but looks like you can get a replacement for $100 or less. Warranty on small appliances are usually a max of one year, but you would have to check your paperwork.
My Blender is not working.I can presume that it's motor have som problem...In this morning I used this blender and suddenly stopped to work....
not sure what that could be,if you have no power at all,i would first check and make sure the fuse is ok.
or try plugging it in another outlet to to make sure its not the outlet thats faulty.
1helpful
My 55 year old waring blender model #1037 has stopped
What I would do is try to see if the manufactor is around yet, like maybe looking on the internet for them or if you have the paper work yet for it look for a phone number on it and see what they say,or maybe a repair man in your area knows what to do about it.
Jan 09, 2013 • Blenders
I bought it this summer on line and it is not spinning even though the motor is running. It does spin in pulse cycle, however.
Hello :
It seems that the base of the button is not working properly . You need just to change the base of the button or fix it . I recommend taking it to the service . Since you bought it lately I would recommend replacing it if you still have the guarantee.
good luck .
please rate !
3helpful
2answers
Russell hobbs rhhb3 handheld stopped working
Yes, pry the display cover off and you will find 2 screws. You will find a switch and circuit board. From the circuit board to the switch you will finf a fuse. This is probaby the problem.
1helpful
2answers
Blender suddenly stopped working while in use, lights are on
The motor has burned out. Check with the manufacturer about warranty status for the blender or exchange it.
3helpful
5answers
Oster 6700 Gasket O-ring leaks
Gasket is not the problem.
Square shaft that is pressed into the turning gear is not tight and allows leaking through the connection.
Only repair is to replace the assembly with the gear drive, blades, etc. and this will take care of the leak. The "O" ring gasket is fine and holds the liquids. However the leak is around the center of the shaft that goes through the bottom.
Regards,
Gary
1helpful
2answers
25-30 year old Bamix M100 - 240V 100W
Those small plastig bungs do come out, you will need a fine probe to prise them out then you will see 2 philips head screws which hold it all together, not sure how you will tighten your shaft though, looks like it might be moulded into the plastic retainer, good luck! on mine the motor bearings are seized,
regards,
Dave Pary.
2helpful
2answers
Hamilton beach 4200 water dispenser
i have had this unit for 2 years and the first thing that will go out is the cooling fans, they either stop altogether or start making a loud noise. i suggest to anyone else who has this to go to a computer store and buy 2 quality 90mm fans, they will screw and connect right into the unit. mine initally died about 4 months into use and after replacing them with good fans i never had a problem with it. mine however is a dust magnet and if i dont remove the fans and clean off the heatsinks about every 3 months, the water wont get very cold. mine now is starting to leak water, a big loss since we use this thing all the time.
Mar 01, 2008 • Blenders
Top Magic Bullet Blenders Experts
Mike Cairns
Mike Cairns
john h
ADMIN Andrew
ADMIN Andrew
Are you a Magic Bullet Blender Expert? Answer questions, earn points and help others
