Konica Minolta 1580 MFP Printer, i refilled researched a lot and found that no issue with toner.. we need to reset the printer ...... i dont know how
Konica Minolta 1580 MFP Printer, i refilled the Cartridge, still its show the message replace toner and not printing ... please help how to reset the printer settings... i have researched a lot and found that no issue with toner.. we need to reset the printer ...... i dont know how
Replace toner cartridge or did you fill it your self, if there is a chip on the cartridge and you refill your self then the old cartridge is still old. Are you using 3rd party or OEM? replace with oem
Basically -no. If you could get a reset chip for it, you could probably carry on using the original drum for some time. For example http://www.tonerstop.com.au/konica-minolta-bizhub-c353-bundled-set-of-4-compatible-drum-chips
The toner cartridge has a chip that calculates the estimated usage of the toner and once it reaches it's capacity (per estimation), it will not print. The only thing you can do is to buy a new cartridge or buy refill toner that comes with a reset chip.
You need the chips to tell the printer which color is installed. You can put your old chips on the toners and set the engine menu to continue on errors to print even when the counters show that it should be out..
Unfortunately you have to replace the chip or to reset it after the toner refill. The chip keeps count of the number of pages that was printed with that toner, so there is no easy way out.
Chip reset device for Konica Minolta Bizhub and CF imaging units http://www.chipreset.eu
You need to be careful about the size of the grains in the toner. I would use toners from other printers of the same make and model series, but when you go outside them you really need to know the exact natue (specifications) or the toner you use. The chips just reset the counter that the printer tracks to tell you when you are just about out, but they are not critical for operation, but you must set the print engine to continue on error.
To clear chip after refilling toner cartriage.
Go to "Tonerfillyourself.com" I bought refill toner and it includes a new chip and it's not hard to replace it. (Comes with instructions)
