SOURCE: red L.E.D light won't stop flashing
Shaving head check indication After two years of use the red shaving unit symbol î will flash for 30 seconds during 7 shaves to indicate that you should check the condition of the shaving heads. This indication is based on an average shaving time of 3 minutes per shave. When the shaving head symbol flashes, all other symbols and lights are out. When the shaver is switched off, the shaving unit symbol disappears. When the red shaving unit symbol starts flashing, you should check the shaving heads for possible damage. If the shaving heads are damaged in any way, they must be replaced in order to obtain optimal shaving results
SOURCE: Delta Faucet (Series 2467) Sprayer doesn't work
Yes, the diverter assembly is probably corroded or clogged shut. Garunteed its the problem on a 10 year old delta kitchn faucet.The diverter routes water from the spout to the sprayer when the sprayer is triggered.
SOURCE: I have a JVC HD52z575 that when I turn it on the
Power supply would be the issue the fix would be my good friends @ www.teexp.com I hope this helps.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: my delta faucet pull down diverter tub spout is
It sounds like it could be manufacture defect. Take it back for a new one.
We have the same problem
same here, the blue light stopped working. red still works
Same problem here, too. It's been a couple of years since the blue light quit working, and I haven't done anything about it. Now the solenoid is starting to fail, and the electronics are out of warranty, so I'm thinking of replacing the entire faucet with a non-electronic version. That'll take care of the blue light. :-)
I am having the same issue as well, no blue light
You're lucky the blue light ever worked! The blue light was one of the reasons I chose this faucet for my new kitchen, but once it was installed...it never worked at all!! I should have made contractor remove it and bring me a new one. (The red light that I never cared about at all, works fine though, go figure).
